2009 G37 Instrumental and Gauge Cluster not working, Car won't start
Old Jun 25, 2025 | 11:24 AM
boisphotography's Avatar
boisphotography
Hello Everyone,
First post need help!
Yesterday I was able to start my G37 but the instrumental and gauge cluster did not turn on and was able to run and drive to work. On my way back my car died and I had to push the vehicle until I could get it towed back to the driveway. So far I have tested some of the fuses and grounds with a multimeter and also I had tested the battery which seemed in good shape. The car does not start since the initial death. It clicks but doesn't turnover. If anyone has had a similar problem I would love some advice. The model is 2009 Infiniti G37s coupe. Thank you for the help.
So far we have checked the fuses and replace the starter, it is still clicking but not turning over still.
Old Jul 18, 2025 | 03:54 PM
McStealth's Avatar
McStealth
Originally Posted by boisphotography
Hello Everyone,
I had a starter issue that was wrongly diagnosed as a solenoid problem. Have you bench tested the starter? Both starters for that matter? Not sure if that would coincide with a blank screen though.
Good Luck.
Old Jul 23, 2025 | 05:44 PM
boisphotography
My friend and I found the issue, I had a faulty reverse taillight that was causing a fuse to blow every time I went to reverse! Thank you for your help, it is much appreciated!
Old Jul 24, 2025 | 11:12 AM
McStealth's Avatar
McStealth
Fuse
So it was the blown fuse that actually kept the car from starting. What made you look at the fuses?
David
carterryanf
Aug 31, 2023 09:05 PM
BrokenBoy
May 9, 2021 08:02 PM
g37tx
Jun 17, 2016 02:28 PM
G37FTW
Feb 5, 2015 02:04 PM
9Gear x
Nov 22, 2014 03:00 PM
