Broken part near rear end links
Old Nov 18, 2023 | 08:53 PM
JUANPCM's Avatar
JUANPCM
I found this broken part under my car, does anyone knows what it is??
Old Nov 19, 2023 | 03:01 AM
SkysG37's Avatar
SkysG37
It broke
If its out back,active steering component?
Up front, active headlight stuff?
Old Nov 20, 2023 | 01:30 PM
JUANPCM's Avatar
JUANPCM
thanks, yes, its out back, pretty close to the left side end link, it has a similar shape to an end link, just a straight cylinder connected with 2 screws, 1 to a metal bracket and the other side to like a lever thing that has some cables above it and its only on the driver side, any ideas? couldnt find it on FSM
Old Nov 29, 2023 | 09:07 AM
ILM-NC G37S's Avatar
ILM-NC G37S
It is the height sensor for the AFS (adaptive) headlights.
Old Nov 29, 2023 | 10:23 AM
JUANPCM's Avatar
JUANPCM
Yeah, thats the one.. Thank you ILM, what does it do? is it only one? my left light doesnt move when i steer the car just the right one, could that be the reason?
Old Nov 29, 2023 | 11:13 AM
ILM-NC G37S
Unfortunately, I've not the time nor energy to fully assist with your issue, however, section EXL (Exterior Lighting) will have all of the info needed on diagnosing AFS.
That said, that is a height sensor. It's sole function is to measure changes in rear height based on loads (rear seat passengers and/or cargo in trunk) and send that signal to the control unit which adjusts the VERTICAL aim of the projectors to keep the beams level. In other words, if you have too much "junk in the trunk" your headlights will stay level and not point up to the sky.
Being that you are having a HORIZONTAL aiming issue with ONE lamp likely points to an aiming motor issue within the lamp itself not the SAS (steering angle sensor) which signals HORIZONTAL alignment. Is it possible the height sensor could be the issue? Possible not probable. I'd still replace it with a junkyard sensor and go from there.
Good luck.
Old Nov 29, 2023 | 01:18 PM
JUANPCM's Avatar
JUANPCM
Thanks ILM for the info, appreciate the explanation, i will replace the sensor to see if it helps
ChefMatt
Apr 18, 2022 11:32 AM
petemo94
Feb 14, 2022 08:13 AM
Fan JiaChen
Jun 14, 2020 08:15 PM
v36type
Sep 9, 2018 07:23 PM
Presto
Sep 8, 2016 04:00 AM
