2008 G37 hard shudder when shifting from 2nd to 3rd
Old Apr 7, 2023 | 09:21 PM
ninefingerz's Avatar
ninefingerz
Hello All,
I have the 5AT RE5R05A (I think?) in my 2008 G37. A couple of days ago the tranny all of the sudden started shuddering fairly violently for 1-2 seconds when shifting from 2nd to 3rd gear. I've only had the car for about 6 months, and thought I could feel a little vibration when shifting into 3rd in the past, but is was subtle.
I checked the fluid, and it was a little low, so I added about half a quart, but same results.
There does not appear to be any coolant in the fluid, and no fluid in the radiator.
Any thoughts on this? Should I go after the valve body or tranny itself? There isn't squat for info on the web about common failure modes for these trannys which I thought was unusual.
Not really sure where to start. Any help would be appreciated. Thanks!
Old Apr 8, 2023 | 09:53 AM
dkmura's Avatar
dkmura
20 Year Member
Have you checked the FSM for the correct procedure to change tranny fluid?
Old Apr 15, 2023 | 09:09 PM
fpssource's Avatar
fpssource
Check your battery if it has any loose connection. I had a issue with my 08 coupe transmission shifting very weirdly by jerking hard and had a rough start, went to mechanic and he fixed it by tightening battery connection.
siglol
Mar 5, 2023 03:19 PM
WhiteVQ37
Jul 15, 2019 10:21 AM
wagonmaster69
Sep 14, 2018 02:48 AM
richysh
Jun 4, 2016 10:35 AM
abodrc
Mar 18, 2016 04:44 PM
