2008 G37 6MT Car won't Start Key Light On
Hello. I have a 2008 G37 6MT about six months ago the steering lock bricked my car. I couldn't start, roll up windows, alarm, etc. I checked fuses, hit it with a hammer and got it to work 2 times. after that it would not work. I ordered a new steering lock, Pulled the column out and changed it out. I was able to get control of the car again, windows, alarm, unlock/lock car, radio etc.. Everything but start. It will not start now. When I push the button it shows the clutch icon, but doesn't start with clutch pushed in. The key light remains on the dash. I can go to the acc, play the radio etc.
2 sets of new batteries in both key fobs.
I changed out the clutch sensor thinking that might be it. That didn't work.
'I had pop a lock come by yesterday to see if the key was programmed to car. He said the car is recognizing the key so it's got to be something else.
I purchased a BCU but have not installed yet. The tech saw it on the seat and asked if I changed out. He said that would brick my car and they couldn't program, would have to be done by dealer.
Any suggestions? It's a 2008 with 100K miles on it. Still in great shape but doesn't warrant towing 26 miles to dealer and their outrageous price.
Also last night I noticed the brake lights were still on even though the car was alarmed. No headlights are running light in the front.
These two threads, while not identical to your issue, has details about the switch and the bumper pad:
https://www.myg37.com/forums/g37-sed...code-help.html
https://www.myg37.com/forums/engine-...ard-brake.html
A simple test, try pulling the brake pedal UP or wedge a coin between the switch plunger and tab and try starting the engine.
I looked at the brake pedal last night. The rubber bumper pad was missing. There was a broken piece of rubber on the carpet. I pulled the bumper pad off another break part I have and the lights went off when car was locked. Did not help in starting car. Still same symptoms. Press start button, clutch logo comes up, as soon as I press in clutch it goes away but does not start and the key light is still on. Back to the drawing board.
I ran another scan on the car and this is what I get. I have a bcm and ordered the IPDM. I know the BCM will require reprogramming, not sure about the IPDM
Most of the BCM codes are incorrect. Says all four tires are flat.
I'll start with the IPDM since the starting is the problem.
2008 Infiniti G37 V6, 3.7L
JNKCV64E38M119221
Odometer: 103,039 miles
B2014-
00
CONFIRMED
Strg Comm2: No Sub Type Information
B2553-
00
CONFIRMED
Ignition power circuit: No Sub Type Information
B2562-
00
CONFIRMED
Low voltage: No Sub Type Information
B2607-
00
CONFIRMED
Steering lock relay: No Sub Type Information
B2609-
00
CONFIRMED
Steering lock condition: No Sub Type Information
B260F-
00
CONFIRMED
Engine state signal lost: No Sub Type Information
Page 1 of 3
0 Confirmed Codes
0 Pending Codes
0 Permanent Codes
14 Body Control Module Codes
© BlueDriver 2019
Scan Report - 2008 Infiniti G37 V6, 3.7L
B2612-
00
CONFIRMED
Steering lock condition (Intelligent Power Distribution Module engine room): No
B2619-
00
CONFIRMED
Bcm: No Sub Type Information
C1704-
00
CONFIRMED
Flat tire front-left: No Sub Type Information
C1705-
00
CONFIRMED
Flat tire front-right: No Sub Type Information
C1706-
00
CONFIRMED
Flat tire rear-left: No Sub Type Information
C1707-
00
CONFIRMED
Flat tire rear-right: No Sub Type Information
C1710-
00
CONFIRMED
(No Data) Rear-right: No Sub Type Information
C1711-
00
CONFIRMED
(No Data) Rear-left: No Sub Type Information
B2099-
00
CONFIRMED
IGN relay OFF failure: No Sub Type Information
B2109-
00
CONFIRMED
Steering lock relay off: No Sub Type Information
B210A-
00
CONFIRMED
Steering lock state switch: No Sub Type Information
Page 2 of 3
3 IPDM E/R Codes
JNKCV64E38M119221
B2014-
00
CONFIRMED
B2553-
00
CONFIRMED
B2562-
00
CONFIRMED
B2607-
00
CONFIRMED
B2609-
00
CONFIRMED
B260F-
00
CONFIRMED
Page 1 of 3
0 Confirmed Codes
0 Pending Codes
0 Permanent Codes
© BlueDriver 2019
B2612-
00
CONFIRMED
B2619-
00
CONFIRMED
C1704-
00
CONFIRMED
C1705-
00
CONFIRMED
C1706-
00
CONFIRMED
C1707-
00
CONFIRMED
C1710-
00
CONFIRMED
C1711-
00
CONFIRMED
B2099-
00
CONFIRMED
B2109-
00
CONFIRMED
B210A-
00
CONFIRMED
Page 2 of 3
3 IPDM E/R Codes
the IPDM codes
B2099-
00
CONFIRMED
B2109-
00
CONFIRMED
B210A-
00
CONFIRMED
Page 2 of 3
B2099-
00
CONFIRMED
B2109-
00
CONFIRMED
B210A-
00
CONFIRMED
Page 2 of 3
brassman
General Tech Questions
Nov 15, 2013 04:55 PM
