ECU possibly wet?
Old Jan 15, 2023 | 03:42 PM
rcortez707's Avatar
rcortez707
ECU possibly wet?
Hello everyone, as you may know, these cars are notorious for water leaking in thru the sunroof. Well anyway, it rained and water got inside thru the front passenger side. I turned off the car and the dashboard lit up like a christmas tree and a bunch of other issues like the car not being able to shut off. Any one know if its possibly the ECU? And where can i get another one programmed?
Old Jan 15, 2023 | 04:14 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Given its location and your symptoms, it is more than likely the BCM got wet, not the ECU.
You can try (w/ battery disconnected) disconnecting and removing the BCM to dry it out. Also, make sure all the connectors are clean and dry. Then, plug everything back up and see if the car returns to normal. If not, you'll have to replace the BCM.
There are plenty on eBay and other used parts outlets, just keep in mind you'll need to match your car's specs. Also, you'll need a QUALIFIED/ REPUTABLE locksmith to reprogram everything.
Old Jan 15, 2023 | 04:20 PM
rcortez707's Avatar
rcortez707
Thank you! Honestly im stressed out with this stupid rain and issues. Do you think the dealership can just take care of this issue for me? Lol
Old Jan 15, 2023 | 04:33 PM
ILM-NC G37S
Of course the dealer can fix the issue. But it will cost you a small fortune.
Also keep in mind, the windshield cowls are known to be a source of water leaking into the cabin and, being a Coupe, the door seals are known to leak as well.
Been there/ done that- all three sources.
Old Jan 15, 2023 | 05:10 PM
rcortez707's Avatar
rcortez707
What would you recommend?
Old Jan 15, 2023 | 07:56 PM
ILM-NC G37S
That is a judgement call only you can make. It depends on your level of skill vs. how wide you want to open your wallet.
If it were me, I would do as I described above. The electrics in these cars is pretty stout. There is a good chance that once everything gets dried out everything will return to normal. It has happened before to other members.
After that, if the car still does not work, then you can determine what course of repair you want to take.
Mike730
G37 Convertible
12
Jan 26, 2023 04:07 AM
Var
Aug 29, 2021 09:58 AM
Bonez_850FL
General Tech Questions
May 30, 2020 11:02 AM
keithnellie
Feb 23, 2019 10:02 PM
