Car not recognizing key
Old Oct 2, 2022 | 08:57 PM
Imtoosmooove's Avatar
Imtoosmooove
(Help) Car not recognizing key
2008 infinity g37 base coupe
pretty stumped on this one, car left me stranded because I got out to pick something up and turned car off, returned 30 seconds later and could turn the car to on or acc mode, can’t lock and unlock car, or literally anything.
ive replaced the positive terminal fuse and assembly,
wiggled the steering wheel
inserted the key into the slot
held the key up on the push start
tapped the steering lock module
took out the steering lock fuse,
checked the BCM for water damage,
replaced the key fobs battery’s,
replaced all electrical fuses
only thing I haven’t done is replaced the BCM, steering lock, and keyless entry module. I’m currently looking for the keyless entry module as we speak. Any ideas?
Old Oct 2, 2022 | 09:45 PM
needsoju's Avatar
needsoju
Have you tried with another key?
just trying to rule out if the issue is with the keys or something else.
Old Oct 2, 2022 | 09:55 PM
Imtoosmooove
Don’t have another one 😬
Old Nov 30, 2022 | 08:44 PM
Imtoosmooove
Ended up being that it was just the cheap key failing. Got new key and everything worked
Old Dec 5, 2022 | 07:04 AM
zoe infinity's Avatar
zoe infinity
what did the dealer tell you about this
Mvtt
May 18, 2026 09:19 AM
jakethedog
Sep 10, 2022 09:30 PM
Rafa
General Tech Questions
Sep 26, 2019 05:11 PM
Hani504
Apr 11, 2017 01:32 PM
Caruth_less
Dec 14, 2016 12:03 PM
