Help! Odometer not logging miles accurately
Old Jun 8, 2022 | 06:33 PM
armash140's Avatar
armash140
Exclamation Help! Odometer not logging miles accurately
Hi everyone,
I'm in the process of obtaining a used 08' G37S 6M/T from an auction. Everything is fine apart from this issue where the odometer does not record the distance traveled accurately. For example; we drove it approximately 7 miles, but the digital odometer only logged 1.4 miles.
Has anyone else had this issue? Any idea what might be the problem? I also have the option of voiding the sale, should I just save myself the headache?
Thanks for your time. It's been such a long process trying to get this car but now I'm once again at a stand still.
Old Jun 8, 2022 | 10:36 PM
ILM-NC G37S's Avatar
ILM-NC G37S
The issue could be a faulty wheel sensor(s) , ABS unit, AC amplifier, cluster, or a myriad of other things (including intentional tampering). Odometer failures are EXTREMELY rare these days... It is just impossible to diagnose here.
It is your call whether to buy or walk away. If the car is mechanically sound and in decent shape (for a 14/15 year old car) and the price is right then give it your due consideration.
Then there is my golden rule: "If in doubt, don't."
Old Jun 8, 2022 | 10:45 PM
armash140's Avatar
armash140
So, everything else is working. Speedometer, no lights on the dash reported, etc. and the wheel diameter is correct. I can't get them to send it to a repair shop for a diagnosis cause they will just charge me further. it's so annoying lol.
It sucks cause this has been such a long process for me, and now I'm just at a standstill.
Old Jun 9, 2022 | 09:16 AM
ILM-NC G37S
Above briefly shows all that is involved in the odometer system. Any variable in that diagram can be suspect or, as I alluded to before, intentional tampering.
Are you able to work on your own car or would you be paying a mechanic?
The main issue that would bother me is not knowing the true mileage of the car and potentially having issues with the DMV in your state with registration/ titling/ etc. as, technically and legally, mileage discrepancies must be reported.
Either way, welcome to the site and keep us updated on the outcome.
Old Jun 9, 2022 | 11:15 AM
armash140's Avatar
armash140
Hey!
Thanks so much for taking the time to respond to my questions. I really appreciate it.
I decided to void the sale following the golden rule. I just want peace of mind in the end. I hope to find something better with patience.
Old Feb 27, 2023 | 11:00 PM
ArcticMinibike's Avatar
ArcticMinibike
I have this problem as well - need help!
Hi, new member here, but veteran of a G35 forum.
I just purchased an '08 G37s. I drove it home 405 miles. Afterward, I realized it only registered 135 miles. It's almost exactly 1/3 the actual miles. I reset the trip meter and did a test drive along side of some friends. I registered a fraction of the miles they registered. MPH is accurate. I have every reason to believe the person I bought it from was on the up and up, but I would think he would have had to have noticed the problem. How could he not? The odometer would be telling him he was getting only 120 miles per tank of gas. Before I started my trip home, I was running through the menus and hit reset on the fuel economy feature, or so I thought. Did I unknowingly change something? That couldn't possibly impact the odometer reading itself. Is there a known issue with these?
Is the true mileage stored in more than one place? Could a dealer use a diagnostic tool to read it correctly. Perhaps it's the cluster that's the problem? I also have a G35 where cluster failure is a major known issue. I see from an earlier post that there are numerous possible points of failure.
Old Feb 23, 2024 | 05:14 PM
ArcticMinibike
Problem Solved!
SUCCESS! I first tried a new instrument cluster at the recommendation of a quality cluster repair shop, as that is apparently where the math occurs. No difference. I sent that back. I replaced the AC Climate Amplifier Module and problem solved! Thank you so much for providing the info. It's so bizarre that a bad AC Climate module could cause such a strange problem. That is the last place I would have thought to look. Routing the signal through there is crazy enough, but I would have thought that if the module was bad, the odometer wouldn't work at all, not impact the incorrect count in a reliably consistent manner. Thank you!!!
RealSuToL
General Tech Questions
May 22, 2022 08:46 PM
Koval88
Jan 15, 2016 06:15 PM
armino41
Oct 8, 2013 08:28 PM
STOOF
Nov 5, 2011 03:32 PM
