Engine swapping
Old Dec 15, 2021 | 08:00 PM
Boom63's Avatar
Boom63
Engine swapping
Would Q40 engine swapped into 09 G37x be compatible ? If not what steps would I need to take ?
Old Dec 16, 2021 | 08:25 AM
projectpanda13's Avatar
projectpanda13
you can swap in any VQ37VHR from any year 370z, G37 (rebadged Q40 and 2014/2015 Q60), and 2014/2015 Q50, and Q70.
if you are buying a rwd engine, just swap the upper and lower oil pans from your old awd engine. Everything else is good.
Depending which engine also, you may have to swap some accessories.
Old Dec 16, 2021 | 07:31 PM
Boom63's Avatar
Boom63
It’s AWD so I wouldn’t have to get a new tranny because it’s new engine?
Old Dec 16, 2021 | 08:09 PM
projectpanda13
no need for a new or another transmission, it’ll bolt up to your current
Old Jun 15, 2022 | 05:13 PM
Moonlight_g37's Avatar
Moonlight_g37
Is the sensor location and wiring harness the same also? And would my g37 ecm and pcm work with this new motor?
Old Jun 16, 2022 | 09:12 AM
BULL's Avatar
BULL
Moderador
In summary, yes it will.
Old Jul 20, 2022 | 06:50 PM
bkgoetz's Avatar
bkgoetz
Quick question:
Working on a swap in my 2009G37X. I bought a donor 2012G37X engine for the swap. Everything is going fine until hit the O2 sensors. The 2011 and up O2 sensors and plugs are different.
Is it possible to cut and splice the plugs from the 2012 O2 Sensors onto the 2009 wiring harness and use the newer O2 sensors that the 2012 use?
Other option would be to try to swap the newer 2012 O2 sensors with the older 2009 sensors from the old engine.
Any thoughts?
Thanks for the help!
Old Jul 22, 2022 | 04:50 PM
projectpanda13
you should be able to spice the wires. It'll be the same, its only the plug that's different.
its defintely easier to reuse your old sensor.
Old Aug 19, 2025 | 01:10 PM
facemelter75's Avatar
facemelter75
How'd this work out?
MoeG37
Mar 27, 2021 09:51 PM
Tatus
Mar 16, 2021 10:32 AM
G3sevenn
Feb 28, 2020 09:21 AM
G37xsnewguy
Oct 28, 2017 02:21 AM
last lemming
Feb 9, 2009 11:07 PM
