G37 coupe 3” long tube intakes
Old Sep 24, 2020 | 09:16 PM
Jmapodacatx1's Avatar
Jmapodacatx1
Hi everyone. This is my first post. I have a g37 coupe. I decided to make my own 3” dual intakes. They look great. The issue I’m having is with cold starts. The MAF can’t read enough air flowing though them. The car thinks that there’s no air flow so doesn’t give it enough gas. I’ve done the idle relearn successfully but it’s done when the car is warm and it hasn’t help. I’ve also tried moving them closer to the throttle body with no luck. Is the a MAF that I can purchase with more sensitivity. Would a Tune be my only option? Thanks in advance for any help.
Old Sep 25, 2020 | 02:27 AM
Kpmikey808's Avatar
Kpmikey808
think stillens is 2.75 & doesn’t need tune- moncef from Admin said u would guarantee need tune for 3 inch cai
Old Sep 26, 2020 | 12:47 AM
Jmapodacatx1
Thanks for the info. I’m in SA does anyone know where I could get a tune locally?
Old Sep 26, 2020 | 02:45 AM
Kpmikey808's Avatar
Kpmikey808
how far are u from Houston ? Moncef at admin tuning is a master tuner
Old Sep 28, 2020 | 12:23 PM
EMPIR37's Avatar
EMPIR37
If you fabbed this, then you can make a reducer like AAM/Nismo Setup.
https://aamcompetition.com/i-1186016...r-intakes.html
Obviously some of the performance benefits are gone, but you wouldn't have them without a tune anyway.
Old Oct 4, 2020 | 03:53 PM
Jmapodacatx1
Thank you very much.
I cut the 3” before the MAF and made a 2.75” reducer, welded in and it help a whole lot with the cold start. Still has a slight hesitation at cold start but evens itself out. Idles perfect when warmed up and no issues when driving.
SupraOfDoom
Intake and Exhaust
Sep 29, 2020 11:08 PM
mikep
ECU Tuning / Dyno Data
Sep 10, 2018 02:04 AM
sboucher
Intake and Exhaust
Nov 8, 2017 12:52 AM
MNoriegaG37s
Feb 25, 2017 05:51 PM
kdawg8526
Intake and Exhaust
May 26, 2016 11:14 AM
