Lights stay on once car turned on
Old May 28, 2020 | 03:02 AM
getemdoug's Avatar
getemdoug
I switched from a 6MT Sport Coupe to IPL 7AT and have no mechanical issues but my exterior lights (excluding fogs) do not turn off. The light column functions properly in the ON position but the only way to keep lights from turning on once the car is started is to engage the parking brake prior to ignition. Dealerships dont know this issue and the INFINITI/Nissan specialists I’ve spoken with still haven’t gotten back to me yet. If this turns out to be a bigger issue then I’ll probably have to find another one again with black interior. But maybe I’ll find a 6MT. I wouldn’t mind if this could be switched to the fog lights ONLY being on all the time but all my lights don’t need to be.
Old May 28, 2020 | 08:08 AM
ILM-NC G37S's Avatar
ILM-NC G37S
Is your car maybe equipped with DRL's?
Or, are ALL lights (front, rear, AND interior) turning on with ignition?
Old May 28, 2020 | 09:26 AM
getemdoug's Avatar
getemdoug
Headlights tail lights and dash lights are on. Other interior lights function properly. Toggling the exterior lights only turns dashboard lights on and off. Lower Fog lights can be turned off and on as well. It’s also from Canada.
Old May 28, 2020 | 10:37 AM
ILM-NC G37S
With the light switch OFF, when you start the engine the lights come on, yes? Engine running, when you turn the switch ON, the gauge cluster dims, yes?
Sorry for the silly questions, but going over the FSM and I can not immediately pinpoint your issue. It does appear that your DRL system is operating normally. From the 2014 Owners Manual:
Old May 28, 2020 | 01:14 PM
getemdoug's Avatar
getemdoug
This is pretty much what happens but mine is a 2011. If they have DRLs its fine but no way the taillights should be on too but I may be wrong.
Old May 28, 2020 | 02:28 PM
ILM-NC G37S
Perfectly normal. From the shop manual for the 2011 Coupe:
Old May 28, 2020 | 03:31 PM
stealthee's Avatar
stealthee
Some manufacturers are indeed moving to having the tails come on with DRL's because people are too stupid to turn their parking lights/headlights on at dusk.
Old May 28, 2020 | 03:54 PM
getemdoug's Avatar
getemdoug
Sad. Thanks for the info. At least I know it’s not a malfunction
Old May 28, 2020 | 06:29 PM
ILM-NC G37S
Nanny Technology: the ultimate cause of death of the pure driving experience.
martik00173
Aug 28, 2019 08:56 AM
Brianne Maloney
Apr 9, 2018 10:58 AM
zonnie
Feb 17, 2017 01:21 AM
40something
Jan 2, 2012 01:57 AM
