Engine Light
Engine Light
I will appreciate guidance to clear the Engine Light that turned on in my 2013 G37 6MT came on.
I have tightened the gas cap & is still one.
There is no change in performance or gas mileage. The car is in pristine condition & I would like to keep it that way.
My hope is that there is a simple fix I can do.
Thank you in advanced.
from the code, it will determine you’re next course of action.
don’t speculate until you get that key piece of information. Good luck.
Hard to determine what your issue is based on information provided:
Are you referring to the "LOOSE FUEL CAP" notice on the gauge cluster center display? If so, after tightening the cap, the notice will clear itself after several drive cycles. It does not go away 1-2-3. If it does not clear after a while you may need to replace the fuel cap.
If you are referring to a different notice, or if the CEL is on, you will need to check for any codes then go from there.
Pete: Thank you for your excellent suggestion- I will follow through with Advance Auto as you suggested and hope for the best
ILM: Thanks your reply. The light is amber colored & above the odometer. I retightened the gas cap per the manual. Hope the fix is easy
Engine Light-Update: Got lucky
This is to update my post. Got lucky- procrastination paid for once.
After driving through one tank full in highway, the Engine Light went away on its own. I know the bulb is still good b/c I see it come on when I start the car.
My guess is that it was a minor issue that got cleared with a little spirited driving
I do appreciate everyone’s input, which I’ll keep in mind for future.
buy yourself a code reader.. its the best thing I've ever done for myself. if you're interested on which one I got (99 dollars) I can shoot you a pm.. best part is its not vehicle specific.. so for someone like myself with 11 vehicles as long as they have an obd2 port im good to go
Very true.. But the one I got reads the codes, tells you the fixes, can clear the codes, can save old reads , has an engine diagnostic built in with live reads from your engine in that moment. All of the recalls for the vehicle etc etc etc.. its a beast. can enter a vin and get all the specs of any vehicle put in there.
G37NC
Oct 10, 2016 12:55 PM
davelim
Jan 16, 2012 06:55 PM
lakers8
Sep 9, 2008 10:01 AM
