Tail light HELP
Old Apr 7, 2020 | 08:23 PM
Malek El's Avatar
Malek El
Tail light HELP
I’m trying to take out my tail light and put my other one in but i heard I’m suppose to break the sealing caps?? Because they are a one-time use type of caps. So i guess i have to order two of them before i break/twist them with tweezers. What are they called ? I’m trying to find the proper name for them but i can’t find any where i can order them from. Can anybody help please ???
Old Apr 7, 2020 | 09:44 PM
ILM-NC G37S's Avatar
ILM-NC G37S
DO NOT TWIST/BEND/or BREAK ANYTHING OFF!!!
Remove the three hex nuts and pull the taillight unit straight out. It will be difficult as the clips hold the assembly tight.
I recommend loosening the hex nuts but don't remove them from the stud. Using a rubber mallet (or other soft hammer lightly tap on the head of each nut to loosen the clips. Once the clips pop, remove the nuts and the assembly should slide right out.
The only thing that "technically" needs to be "replaced" are the packing seals. IIRC, they are little rubber "washers" that go on the metal studs between the tail lamp and the car body. I doubt anyone has ever replaced them. I never have.
Old Apr 8, 2020 | 11:43 AM
jpowersjr2's Avatar
jpowersjr2
^ Good advice.
I never replaced those seals either lol. I think I'm even missing a hex nut ha.
Old Apr 8, 2020 | 01:18 PM
ILM-NC G37S
For those inclined, the part number is 26553-85L00 and they cost $10.38/ea. from parts.infinitiusa.com as of 8 April 2020:
Mighty expensive rubber washers.
Old Apr 8, 2020 | 06:26 PM
josephwhan's Avatar
josephwhan
I broke both sets. They're fine just as they are when you put them back in. You won't need to replace the parts. Or use a rubber mallet to push them out.
Old Apr 8, 2020 | 11:20 PM
AdamBritt's Avatar
AdamBritt
Are you guys afraid of Nissanpartsdeal? The same part number on there is $6.97.
MHO14225
Jul 25, 2011 02:39 PM
BANGA
18
Jan 12, 2011 04:31 PM
NIGHTLFEphantom
Mar 13, 2009 02:10 PM
PROFLYER
Aug 7, 2008 03:13 PM
