Adding additional G37 parking sensors?
I have a 2013 G37S coupe. In my year, the G37 onon had parking sensors on the rear.
Does anyona know if the parking sensors are wired in parallel? If so, I'm planning to purchpur additional sensors and add them to the front.
It is not as simple as punching holes in the bumper and adding sensors. Nothing is ever that easy!
Each sensor has two wires: one signal wire connected directly to the SONAR CONTROL UNIT buried somewhere in the dashboard and a common ground wire that branches off from the main ground at the control unit. You would have to run five (5) wires from your dash.
HOWEVER, This does NOT take into account if your sonar controller is designed for both front and rear detection nor if your AV system is preconfigured as well. The only FSM I have for the SONAR is for the 2013 Coupe and it does not mention anything about front detection and there is nothing in the wiring diagrams that show it as a option.
Mike S.
Feb 11, 2017 12:46 AM
MyG37xS
Mar 12, 2013 10:25 AM
