G37 coupe wont go above 3500 rpm
Old Dec 6, 2018 | 12:04 PM
Ishan02's Avatar
Ishan02
hey guys i gave a g37s coupe at 81k miles and it has a problem it keeps showing a p0420 code i took it to the shop and the dude said that the cats aren't the problem the car has 81k miles cats should not be failing. i took it to the dealer and the guy said the repair cost will be 6000+ like what the **** the car isn't even worth 7k im pissed off rn the car is a piece of **** and i cant fix it.
Old Dec 6, 2018 | 12:30 PM
PNW_IPL's Avatar
PNW_IPL
What was the diag at the dealer? Seems to be in limp mode but the p0420 shouldnt put it in limp mode..
Old Dec 6, 2018 | 12:50 PM
Baadnewsburr's Avatar
Baadnewsburr
While I understand your frustration, looking at your other posts, it looks like its been going into limp mode for 4-5 months now almost daily and you have just been clearing the codes ....the car goes into limp mode to protect itself...clearing it and driving for months is not likely to end well....the P0420 could be an O2 sensor too but you should not just keep clearing the codes or at least be recording the codes/a freezeframe of the data as it will only make it more difficult to diagnose the real problem as other codes are thrown...
I don't know about the shop that said cats shouldn't be failing...Cats can fail any time from physical damage too and especially since you have the exhaust modified...you can get used cats on here for about $150 and a pair of O2 sensors is about $200 for new aftermarket sensors...but thats probably only gonna help if you're throwing parts at it...the daily limp modes sounds like a much more serious problem, maybe the oil gallery gasket...
Either way, its unlikely the car needs 6k in work in a worse case scenario even from the dealer...an engine swap can be done for half that or less....the $6k probably includes bunch of other maintenance items, you can always post up the estimate here and ask about prioritizing/necessity of particular items like lots of there people do...if its something really bad, you can probably have it fixed for less than 3k, but you haven't posted much info, anyways good luck
Harmz
Jan 30, 2018 07:14 PM
nogoer
Jun 9, 2016 11:07 AM
MarkInKeizer
General Tech Questions
Jun 5, 2015 01:52 AM
jaxtraw
Sep 6, 2010 01:24 PM
15951
Apr 30, 2010 11:41 AM
