2008 G37 Exhaust Rust
Old Aug 9, 2016 | 11:28 PM
DrizzyDrake1's Avatar
DrizzyDrake1
I just recently got a 2008 G37 with 49,000 miles and when I looked underneath it I saw that there was some pretty decent rust on the exhaust system. Just wanted an opinion on if this is too much rust and if I should consider doing something about this. Also what can be done about this other than getting a whole new exhaust system. I'd appreciate any feedback, thanks.
Old Aug 10, 2016 | 12:02 AM
Welcome to the site, and yeah, looks pretty bad. Not much can be done there, if it was the body rusting that might still be covered but not the exhaust. A new axleback setup would be the plan unless you want to go full cat-back. Axlebacks such as Top Speed & Beluga look nice and cost $300 or less, a quality catback would start around $1k.
I assume you live in a place w/ harsh winter, or at least the car came from such a place.
Pretty common in the rust belt.
Old Aug 10, 2016 | 01:00 AM
DrizzyDrake1
I mean does it look like it seriously needs to be replaced ASAP?
Old Aug 10, 2016 | 01:09 AM
Epiphany's Avatar
Epiphany
Looks quite similar to my 2012 sedan, or any car that's more than 2ish years old here. Winter isn't friendly to cars.
Old Aug 10, 2016 | 08:19 AM
Not until it starts leaking, and on a vehicle that's not lowered you may be ok for a long time (since you won't be scraping it on a regular basis).
Old Aug 10, 2016 | 09:17 AM
Kris9884's Avatar
Kris9884
I wouldn't replace it unless seeing it just bothers you or its leaking, like blnewt said. Mine was similar while upgrading the axle-back and I had to grind and drill the bolts out. My car was from Texas originally so I don't really know how it happened but, if its just your exhaust, then you're in the clear, easy fix.
Old Aug 10, 2016 | 04:57 PM
JUMBO PALACE's Avatar
JUMBO PALACE
As others have said, it's not an emergency. But for a couple hundred bucks you'll have a shiny new axle back and a much improved exhaust note. If you were thinking of doing any mods now's just as good a time as any.
Old Aug 10, 2016 | 07:55 PM
rsingerG37's Avatar
rsingerG37
Its looks ok to me and as long as there isn't any leaks its fine.
jk315
May 7, 2016 04:21 PM
Envee
Mar 30, 2016 10:28 PM
Trolololol
Mar 29, 2016 03:09 PM
shujz
Mar 17, 2016 05:03 PM
