Gtr start button mod help
Old Jul 16, 2016 | 09:33 PM
Johnnay's Avatar
Johnnay
Anyone had experience with the stock one not coming out with ease?
Following the DIY AND IT's impossible to push it outwards. Doesnt even nudge.
Afraid if I use a flathead to pry it a little, it'll break.
Any tips?
Running a '08 g37s coupe
Thanks all.
Old Jul 17, 2016 | 12:22 AM
kit71185's Avatar
kit71185
Any tips?
Thanks all.
Having same problem. I think it's glued or painted if it's your first time. I kind of give up. Shame. Another person said they took the bottom panel out, remove couple screws and brace and found access easier.
Old Jul 17, 2016 | 01:27 AM
Johnnay's Avatar
Johnnay
I'm thinking it's glued tight as well.
Hate to take the panel out though hoping I don't need to do that however.
Got such a nice modded one to give up
Old Jul 17, 2016 | 01:42 AM
Wow I sold both you guys the modded oem start button and you're both having trouble removing your current one lol ... Pry it out with a flathead but easily. Get it done bc I wanna see how they look!
Old Jul 17, 2016 | 02:19 AM
Johnnay's Avatar
Johnnay
That thing is in there tight man! Im afraid if I pry it out, It'll be loose putting it back lol
Old Jul 17, 2016 | 02:22 AM
kit71185's Avatar
kit71185
Yea must be PIA to put it back so how can I deal with that kind of trauma KENNY!??! The damn harness refuses to come off!!!
Old Jul 17, 2016 | 03:38 AM
13G37's Avatar
13G37
MurderedOutG
Wink
Mine was very tight as well. Super tight I was afraid I was going to break it, but I still yanked that SOB out and got it installed. Phewwww! It was a great relief.
Tight as fvck, managed to yank that bitch out.
oh, mine had a little bit of glue.. Idk why. I cleaned it off though.
Old Jul 17, 2016 | 03:50 AM
kit71185's Avatar
kit71185
I knew there had to be glue
Old Jul 17, 2016 | 08:48 AM
KidJai06's Avatar
KidJai06
If you're going to use a screwdriver wrap the tip lightly in tape to keep from accidentally scratching everything up, or better yet pick up a set of plastic panel/trim/molding tools from HF or local auto part store. They make life much easier and you'll find all sorts of uses for them.
Also sometimes taking more things apart for better access is faster than fighting with it trying to use brute force. If you accidentally mess something up you'll kick yourself for not taking the extra time or care. (I've learned this the hard way a couple times in past cars!) Good luck!
Old Jul 17, 2016 | 11:00 AM
j50ny's Avatar
j50ny
I saw this video after I did a swap on mine. It's shows pretty much where you need to press. Definitely won't break it, if you're pushing it in the right spot
Old Jul 17, 2016 | 01:07 PM
kit71185's Avatar
kit71185
I'm not even sure if I'm doing it right anymore, in the gtr g37 swap video the guy mentions to"push the brown ribbed clip." Is this correct? I'm pushing it really hard in with an eyeglass screwdriver and now it's pushed all the way in. Shouldn't the button pop out immediately or do you have to push brown rib clip and try to slide the whole button off??
Old Jul 17, 2016 | 01:27 PM
You need to push the brown clip and pop the entire button out. Tape up the end of a flathead screwdriver and put some force into it. You most likely have some glue on it so jerk it around a few times but give it a little more force each time so you can start to lossening up the glue. After the glue is loosened up a bit the entore button should pop out.
Old Jul 17, 2016 | 01:32 PM
kit71185's Avatar
kit71185
And what's the method to pop button out use the flathead to push button in and push it towards the wheel??
Old Jul 17, 2016 | 01:52 PM
You can just push it back in with your thumbs. You won't need a flathead for that part.
Old Jul 17, 2016 | 02:11 PM
kit71185's Avatar
kit71185
So I think I lost a tooth lol.. J/k but I push that MFer and the harness was loose and the freakin button won't come out so I try to pry it really hard and the button shot me in the mouth. Lesson learned. . . Wear a helmet with visor.
