What did you do to your coupe today?
Old Jul 19, 2016 | 12:05 PM
  #121
Originally Posted by Amrit.bhathal
Got this today in the mail. Thanks Kenny! Can not wait to install it.
Originally Posted by PNW_IPL
Congrats your going to love it! Kenny does it again!!
The brand new gaskets should be arriving today as well according to the tracking info!! You really are going to fall in love with the sound of that exhaust! As much as I love the looks of my Ark I definitely miss my Greddy everyday! But I know it's going to a good home!
Old Jul 20, 2016 | 04:32 PM
  #122
micafd3s's Avatar
micafd3s
Originally Posted by mummy2
No you didn't miss a post. Just an idea that ran through my mind. Sorry about the glare but it comes on with the fog lights.
interesting that most folks debadge but you went completely the opposite..
Old Jul 21, 2016 | 04:37 AM
  #123
mummy2's Avatar
mummy2
Just in case y'all were wondering how I did it..... LED Brake Light Car Logo Light Additional Letter Brake Lights with Suction Cup LED Refit Car Light for Infiniti G25/35/37 JX35-in Light Source from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group, https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1, and some black reusable cable ties from home depot. There's a hole at the bottom of the fog light compartment where you can pass through the wire to connect to the fog light. Then i just went in through the driver side wheel well.
Old Jul 21, 2016 | 05:38 AM
  #124
rovert's Avatar
rovert
Switch Memory Module added to the VDC.
When I turn it off, it stays off.
Old Jul 21, 2016 | 08:37 AM
  #125
bikezilla's Avatar
bikezilla
I like that SMM. Great idea.
Old Jul 21, 2016 | 08:51 AM
  #126
Yeah man that SMM is definitely pretty cool. Good job rovert
Old Jul 21, 2016 | 03:00 PM
  #127
S_G37's Avatar
S_G37
Today I modified my IJDMToy license plate mount. I know that there is a stillen license plate mount for about $85 before shipping to Mount the plate to the tow hook. I didn't want to spent that much money so I bought the IJDMToy one for like $30 on amazon. Once it came in and I installed it, no matter how tight I made the center screw it would still not hold steady and any little bump I would hit would cause the plate to become crooked. I went to home depot and picked up a bracket that would allow the plate mount to be held up in 2 spots (rather than one) and a couple of lock nuts for about $3 and my problem was solved. Hope this helps with some other people who don't want to spend $85 for a plate relocate. Check out the pictures below to see how I modified it.
What IJDMToy sent me along with 1 screw, 2 rubber washers to attach the black plate to the rod and 4 screws to attach the license plate to the black plate
My modifications
How it looked after
Old Jul 21, 2016 | 07:54 PM
  #128
saywat?'s Avatar
saywat?
blue loctite woulda probably solved it
Old Jul 21, 2016 | 07:55 PM
  #129
S_G37's Avatar
S_G37
Tried it and it didn't work I guess there was too much weight in the plate
Old Jul 21, 2016 | 07:57 PM
  #130
saywat?'s Avatar
saywat?
weird i bought my bracket from ebay for 20 something dollars. i used loctite upon first install. i had no issues with it moving
Old Jul 21, 2016 | 08:02 PM
  #131
PNW_IPL's Avatar
PNW_IPL
Loctite did not work for me neither. And thanks to the other guy I can solve my issue
Old Jul 22, 2016 | 01:57 AM
  #132
Lucasmdemele's Avatar
Lucasmdemele
Rovert does this do the same thing as putting the toggle on the green wire to the yaw sensor?if not what does this do?need detailed I talk instructions and link to where you got you s.m.m?
Old Jul 22, 2016 | 03:34 AM
  #133
rovert's Avatar
rovert
Hi, no this does not disable the Yaw sensor.
It only Gives you control over the VDC.
The default for VDC is always on, unless you turn it off with the switch.
Normally if you turn VDC off it comes back on the next time you start your car.
The switch memory module remembers the state of VDC when the ignition is turned off & duplicates that state the next time the car is started.
So it will turn VDC off or on depending on the previous setting.
Unfortunately or fortunately depending on how you look at it, my 370GT being a JDM sports pack it has 4WS. One of the main inputs for the 4WS is the Yaw sensor, so, much harder to take it out of the picture.
That said, this incarnation of Nissans 4WS is pretty friggin good.
Cheers,
Trevor.
Old Jul 22, 2016 | 08:59 AM
  #134
bikezilla's Avatar
bikezilla
I received front and rear spacers, and a set tuner lug nuts that are surprisingly color-matched to my copper calipers.
Oh, and I returned an 11-year old Craftsman torque wrench to Sears and got a new replacement n/c & NQA.
Old Jul 23, 2016 | 11:05 AM
  #135
Valdineide's Avatar
Valdineide
I just bought one today!!!!!!!
