Door lock actuator wires?
Old Jun 9, 2016 | 11:47 AM
mikysee's Avatar
mikysee
The door locks on both sides of my 2011 coupe is starting to fail. I want to install the aftermarket actuators which looks pretty easy. My only question is which and where are the wires that I need to tap into to activate the new actuators? Thanks for any help.
Old Jun 10, 2016 | 04:39 PM
telcoman's Avatar
telcoman
Have you tried following the FSM?
http://www.nicoclub.com/FSM/G37/Coupe/2011/DLK.pdf
Just replacing parts without proving the root cause can end up costing you time and money.
Your problem could be the BCM or the wiring harness?
Telcoman
Old Jun 13, 2016 | 10:54 AM
mikysee's Avatar
mikysee
I can hear the actuator trying to move the lock but sometimes it only moves it a little and not enough to fully lock or unlock the door. I've looked at the FSM and found the plug and pin that is for the lock but it looks like I will have to take a lot of stuff off the door to get to it. I was wondering if any had done this on the g37 and know what colors the wires were.
Jeebus
Aug 25, 2018 10:50 PM
LegitMW
Dec 21, 2016 07:43 PM
Anotherreject
General Tech Questions
Nov 18, 2016 12:52 PM
RANDY350Z
Mar 26, 2016 11:14 PM
