A redline a day keeps the carbon away
I usually hit it a few times a week. i grew up driving Rotary engines so it just makes you go thru the gears. When you really get on it in DS mode it really goes thru the range fast. Some times so fast you get it in your current gear and the next as well.
I also use 102 Octane boost at least 1 time a month. usually on the weekend and end up <10 mpg. The driving style overshadows any mpg benefits and i rely on the performance benefits i think im getting.
I had a Audi tech tell me to redline my V8 S5 to prevent carbon build up. IT would get so bad I would have to have the valves cleaned every 15k miles.
Not really worried about it as much with the G, but like the post below, I hit redline just about every day is manual mode with the 7 at. If I'm feeling real frisky I'll hit redline a few shifts in a row.
You all need to get out of here with that 5k crap. Drive your cars!
I never heard of this Italian tuneup but I'll try that next oil change.... Quick spirited drive... Redline couple gears... U know... Free up some carbon...
Good to do once a week or so. But dont make it an excuse to roar through all gears.
What needs to actually be done is a low rmp full throttle to red line run through just one gear. Pick a larger gear such as 4th is usually the best. Has to be done under load (so no revving in neutral.
If done correctly, will be good for the car.
