Series of interesting questions. NEED HELP/OPINIONS
Old Apr 8, 2014 | 11:19 PM
JerseyG's Avatar
JerseyG
Okay guys, so i just got some extra money, and its obviously going into my car lol.. i have around 500 dollars, and looking to either invest in
1.) Test Pipes / HFC (I have 08 Coupe with Ark Exhaust and R2C intakes) what are the differences in the TP vs. the HFC???
2.) Lowering the car ( I have Ark ) and dont want to be cringing every time i drive,but then again would love to see her low..
3.) TSP Front Lip, looks very nice....
4.) A Tune???
I would love if i can have some extra opinions from you guys, and please share ALL the knowledge you have of the above, it is greatly needed, thanks!
Here are some pics of my car currently.
Attached Thumbnails Series of interesting questions. NEED HELP/OPINIONS-photo-1-.jpg   Series of interesting questions. NEED HELP/OPINIONS-photo-2-.jpg   Series of interesting questions. NEED HELP/OPINIONS-photo-3-.jpg
Old Apr 8, 2014 | 11:43 PM
iBRONXIE's Avatar
iBRONXIE
Get an oem spoiler :-)
Old Apr 9, 2014 | 12:00 AM
I'd hold off on the tune if you're planning on HFCs or TPs, do it once you get all your motor mods in place.
If you DIY the install then you may be able to get it lowered for $500 on springs and rear camber set, but the alignment will put it over $500. If you hold off on the camber kit you can get in budget but in the long term it's best to get your alignment right to keep tire wear to a minimum.
A front lip & rear spoiler will be over $500 but if you look in the right places you might get close to that.
car's looking pretty nice, have you thought about DIY headlight or tailight mods?
Old Apr 9, 2014 | 12:05 AM
JerseyG's Avatar
JerseyG
But my trouble is if I lower the car will it scrape my exhaust that I spent a thousand dollars on lol and no I haven't thought about headlight or taillight mods.. Please elaborate!
Old Apr 9, 2014 | 12:10 AM
Racindaddy's Avatar
Racindaddy
Painted headlights or tail lights. Do a search in the DIY section.
Old Apr 9, 2014 | 12:15 AM
G37Some's Avatar
G37Some
you can also go with the eibach pro kit springs instead of ark. it drops 1.2 / 0.8 vs the 1.5 / 1.0 of ark springs and you shouldn't need camber kits to get back in spec with alignment. you can find that kit under $300 if you shop around but I'm not sure if you want to diy the install. i've heard shops can charge a pretty penny to install springs.
if you can find HFCs for a good price (check for sale section here) I would get that next imho. probably closer to $650 after getting them installed at a shop.
edit; idk how you feel about your wheels but I did get my wheels custom painted for $600. If you wanted powder coating instead of paint, I think depending where you go you should be around that price range too but just my $0.02
Old Apr 9, 2014 | 12:48 AM
Swift, Tanabe, Eibach, or Tein H Tech (not S Tech) are mild drop springs, but if you're that worried just leave it stock, might look into aftermarket sway bars too, those are around $300 and will make a nice difference. As far as headlights here's a link for some ideas
https://www.myg37.com/forums/picture...n-eyes-cf.html
Keep in mind these are done professionally but you can get good results if you DIY, just not w/ as much flair as those in the gallery, unless you have patience & skill.
Old Apr 9, 2014 | 01:47 AM
PongSanity's Avatar
PongSanity
To answer your questions...
HFC stands for High Flow(ing) (Cat)alytic converters. They reduce the cell count from stock to make it more free flowing and still keeping its purpose. Louder than stock cats. Test pipes are basically cats delete. Complete free flow. Test pipes are cheaper but prone to rasp easier. I suggest you do some research on which brand of test pipes or HFC suits your ark exhaust best.
Go Eibach. You won't have to worry about scraping or aftermarket camber kits.
Your decision.
4.) A Tune???
This should LITERALLY be the last thing on your mind in terms of performance. Makes no sense to think on getting a tune if you are thinking on getting HFCs...
Italia311
Jun 28, 2016 11:25 PM
Upscale Speed
Dec 26, 2015 08:45 AM
timc00k
Oct 9, 2015 01:20 PM
EnYcee-G
Oct 4, 2015 09:27 PM
Slapshot1
Sep 27, 2015 08:40 AM
