windshield washer fluid/spray
Old Apr 8, 2014 | 08:40 PM
G37Some's Avatar
G37Some
Is the fluid supposed to spray out like this on the driver side? its all messed up the 3 sprays are like all over the place. if the wiper blades arent moving the spray to the far left gets block. also the middle spray gets all up on my roof. The passenger side is normal, what the hell is going on here lol.
I tried playing around with it but the nozzles aren't adjustable and I also tried to unclog them with a pin and there was no blockage.
Old Apr 8, 2014 | 11:05 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Looks like its misaligned and possibly clogged. They do move, but require quite a bit of effort. I think I used an extended paper clip to realign mine when I got the car.
Old Apr 9, 2014 | 12:33 AM
EnYcee-G's Avatar
EnYcee-G
Mine functions worst than yours. Lol
Old Apr 9, 2014 | 09:06 AM
Dough1397's Avatar
Dough1397
I told my dealer about this and they ended up replacing the nozzles I believe. It was good the summer it got replaced, but after the next winter, the drive and passenger sides were no longer even. No where near as bad as that however. I figure if it gets bad I will use a paper clip or some wire and readjust.
Old Apr 9, 2014 | 01:36 PM
monytx's Avatar
monytx
Lol, I just posted about this. I have the same issue, but I give the person in the car to my right a free wash. One nozzle goes all the way over the car. I wish these cars came with a flat spray instead of the three streams. Feel me?
Old Apr 9, 2014 | 01:56 PM
telcoman's Avatar
telcoman
Try using the point of a small safety pin to adjust the spray nozzle
Telcoman
Old Apr 9, 2014 | 07:06 PM
monytx's Avatar
monytx
Telcoman
I've done it several times, but can never get it to spray right. I still wish it had the flat spray pattern rather than the stream.
Old Apr 10, 2014 | 08:49 PM
G37Some's Avatar
G37Some
after finding a pin, i stuck it in the spray nozzles and maneuvered the nozzles around for about 35 minutes before i got it to spray the winshield properly. it isnt like the OEM setting on the passenger side but it is close enough lol. what a pain in the *** it was actually
Old Apr 11, 2014 | 12:50 AM
evil-G-nius's Avatar
evil-G-nius
part of the problem is that those nozzles (all washer nozzles really) are designed to spray at driving speeds. So at a stand still they shoot over the car and just looks spaztic. If you were cruising down the highway that would have probably hit perfectly on the windshield
Old Apr 11, 2014 | 01:10 AM
G37Some's Avatar
G37Some
unfortunately no, at highway speeds the stream has always been pretty messed up also.
but to fix it u can stick a pin in there and move the nozzles around very very slightly to adjust the spray angle. just takes a while to get them adjust close to normal.
Gefartenblatz
Nov 10, 2015 11:45 AM
2K1 6T8
Oct 6, 2015 07:40 PM
Wreckreation
Sep 21, 2015 06:27 PM
gnawhdivad
Sep 18, 2015 07:02 PM
G10
Sep 17, 2015 11:42 AM
