Need 60k Service Recommendations Help
I have a 2008 G37S - what is recommended for my 60k service? It seems like there are so many options at the dealer I'm having a hard time trying to decipher what is necessary and what is an up-sale. Right now they are telling me that oil change and filter (duh), tire rotation, engine and in-cabin air filters (duh), replace coolant, replace differential, and replace transmission fluid is the minimum to the tune of about $700.
There's a bunch of DYI's on here for most of that stuff. If it's a AT, have the dealer do it. There are special tools and procedures required. The rear end is very easy. You'll need some way of pumping new fluid in. At 60K I'd also be changing out the belt.
All those were recommended for my 30k service. I had them only do the coolant, rear diff and transmission. Everything else I did myself. I only paid close to $300 for the 3 I mentioned instead of close to $700 for everything you listed.
delfinparis
Nov 16, 2015 02:26 PM
Junchao Sun
25
Oct 1, 2015 12:41 PM
