Ticking noise when idling & car is turned off
Source: Just had it done.
If it's a popping sound when the car is turned off BB answered the question at the beginning of the thread. If its a ticking / tapping sound coming from under the car it's most likely the cats. The honeycomb frame inside falls apart and that's what's rattling around. Will be replace by dealership under warranty pending ca's age and mileage
I've had this ticking sound coming from underneath my car for years now. I only notice it when im in the drive thru since I turn off the radio. Doesn't seem like there is anything wrong with the car
Yep mine is the same way. Hear it in the drive thru every time. Its been like that since i got it 2 years ago and i've just left it alone. No engine lights or anything but I want to fix it if it really is just tightening the heat shield.
This is NOT normal when a car is at full temp and the engine is ON and IDLING. It is normal when the car is OFF. There should not be that much cooling while idling to cause it to make this sound.
I think those experiencing the noise are car savvy enough to know what normal metal popping sounds like as it cools.
More than likely, it's one of three things:
VVEL tick (completely normal with these cars). Sometimes using ester oil alleviates this.
Heat shield is loose and knocking around
Cats are crumbling from the inside which is the rattling / popping sound
superjoey
31
03-22-2023 11:56 PM
