Warranty about to Expire
Old Mar 24, 2014 | 11:56 PM
RPG37coupe's Avatar
RPG37coupe
I am the original owner of a 2010 G37 Coupe with 40,000 miles. The car makes a low tapping sound at idle speed. Besides the low tapping sound, any recommendations to encourage the dealer to look at before the warranty expires in 4 months?
Any input is appreciated. Thanks.
Old Mar 25, 2014 | 12:24 AM
MikeKiloDelta's Avatar
MikeKiloDelta
The aluminum trim inside, if its peeling/scratched they'll replace it. They replaced mine without me asking but I was fine with that.
Old Mar 25, 2014 | 08:33 AM
GORILLA GAINS's Avatar
GORILLA GAINS
do you have to be the original owner to benefit from the basic warranty? i bought my g 2 months ago and my warranty should expire in about 5 months. i also have an interior trim piece with a peel spot.
Old Mar 25, 2014 | 12:29 PM
bri's Avatar
bri
Warranty covers the car no matter who owns it. I bought my G just before warranty expired too and had the center console lid replaced because the chrome trim was flaking off. They would not replace any aluminum trim just because it was scratched (said normal wear & tear not covered) but I suspect they would if it was fading or peeling (not normal wear). I have a very light clicking sound when the car is warming up for a minute or so, but have not gotten it checked out.
Old Mar 25, 2014 | 01:16 PM
BLAKonBLAKG37's Avatar
BLAKonBLAKG37
Have them check the bushing on the rear sub frame, make sure it's not leaking...I suspect they noticed mine but didn't mention it until my warranty ran out��
Old Mar 26, 2014 | 07:49 AM
GORILLA GAINS
Can you explain this rear sub frame bushing? and is it common?
Old Mar 26, 2014 | 07:58 AM
Vance67's Avatar
Vance67
The power train warranty will cover the rear subframe bushing. I have a 2010 G37, I'm the second owner & the power train warranty is 70,000 miles...I believe 6-7 years, but should check that, I really don't know.
The rear subframe bushing...you can see if the silicone is leaking by just looking under your car from behind (almost as if you're looking at your exhaust) it's what your differential connects to & your wheels. Not the best explanation & I don't have a pic.
I believe it's about a 1,200 job. Prob won't even notice a difference. Whit leone makes a bushing for it, well for the 370 but it works. Get it done under warranty while you can, will prob happen again if you drive hard, then use white lines. For Infiniti to replace it with oem parts, the whole rear subframe gets replaced
Old Mar 26, 2014 | 07:59 AM
Vance67's Avatar
Vance67
White line makes the bushing replacement
Old Mar 26, 2014 | 08:00 AM
Vance67's Avatar
Vance67
Yes it is common if you drive hard & have a manual...I believe. Can find articles on it like I did if you search for it
Old Mar 26, 2014 | 09:05 AM
Jack10525's Avatar
Jack10525
Start complaining about everything. Engine is rough, idles high/low, trans shifts rough, rear end clunks. Look up all the tsb's and use them as a guide.
fuzzed
Aug 21, 2020 09:35 AM
delfinparis
Nov 16, 2015 02:26 PM
stm37s
The M - Spot
14
Oct 23, 2015 01:56 AM
SpeedBallDEVIL
Oct 2, 2015 11:20 PM
si_driver
Oct 1, 2015 09:53 AM
