Baddest G37x Coupe
Old Dec 27, 2013 | 10:03 PM
  #76
Ryno23's Avatar
Ryno23
Originally Posted by Himalaya
when you put the hood pins in and cut the flush mounting, you should be the first to write a diy for it...
i'd love to get that hood if it fits flush.
I definitely would write up a DIY but I'm just going to have my shop install it. I wouldn't trust myself cutting into the hood lol
Originally Posted by jaymillG37
Ryno, can't wait to see that hood and splitter installed. Do you know if that splitter would fit the sport (non-IPL) bumper?
Thanks man I'm very excited too! Like Himalaya said I'm not exactly sure if it would fit the sport bumper just because I've only seen it on zele and ipl. But if you do go that route, post up some pics. I'm curious to see what it looks like!
Originally Posted by Need 4 Speed
Ryno23,
Very clean! I love it!
Thanks!
Old Jan 2, 2014 | 09:12 PM
  #77
Ryno23's Avatar
Ryno23
For any of you X coupe guys....has anyone considered running a more aggressive squared setup? Im so indecisive when it comes to wheels and and im considering going more aggressive on a squared setup instead of staggered. But I dont know what exact specs I need. Maybe 10.5" all around but im not sure the tires. Also with awd can I go with an tire as long as its the same all around or would I still have to be close to OEM spec? Ive talked to a few ppl about it but have heard different answers from everyone. Could someone help me out or know anyone runnin 10.5 all around on an X coupe?? Thanks!!
Old Jan 2, 2014 | 10:06 PM
  #78
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
10.5 all around sounds pretty intense for the X. I have 9's right now and may go up to 9.5, but that's it, 10.5 would be super aggressive, like fender rolling aggressive.
Old Jan 2, 2014 | 10:36 PM
  #79
Not a coupe but Sedan running 10.5's all around, should be able to pull this off in a coupe since you've got a bit more room for more aggressive offsets.
https://www.myg37.com/forums/picture...g37-sedan.html
Old Jan 3, 2014 | 10:05 AM
  #80
Ryno23's Avatar
Ryno23
I mean if a bunch of guys running 10.5 all around can run it on the S I don't see why we couldn't. Still a squared setup. I def want to make sure specs are all good before I do anything but I think it's possible.
Thanks blnewt! I might have asked you before but not possitive, if I go 10.5 all around what tires and offset would you go with? Can I run any tire size as long they're all the same all around for a squared setup?
Old Jan 3, 2014 | 07:08 PM
  #81
SPDCRZ's Avatar
SPDCRZ
I am running 9.5 all around, that's wide enough for me.
Old Jan 3, 2014 | 07:11 PM
  #82
SPDCRZ's Avatar
SPDCRZ
Ive noticed a lot of people are installing the IPL kit on there X coupes.
Does everyone think its that good looking? I think its okay, but nothing that special.
Old Jan 3, 2014 | 07:19 PM
  #83
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
I was looking at the IPL kit and only ended up with the sidesills. Zele front bumper and AK V2 diffuser. Looks different than all the IPL kits.
Old Jan 4, 2014 | 05:31 PM
  #84
Ryno23's Avatar
Ryno23
Do you have have any pics of the car? Also what offsets n tires are you running?
Old Jan 5, 2014 | 06:42 PM
  #85
SPDCRZ's Avatar
SPDCRZ
[IMG][/IMG]
It just snugs nice.
The offsets, I cant remember off the top of my head actually. I will see if I can figure it out.
Old Jan 30, 2014 | 07:36 PM
  #86
Swag~City14's Avatar
Swag~City14
what kind of body kit is that? and for your rims what size did you use? does it matter that we have the g37x?
Old Jan 30, 2014 | 10:14 PM
  #87
wild_pea's Avatar
wild_pea
Any options for high flow cats for us x coupe guys?
Old Jan 31, 2014 | 09:42 AM
  #88
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
Pretty sure most of the HFCs and TPs fit the X coupe. I had Fast Intentions RTPs for a while and they fit perfect.
Old Feb 1, 2014 | 12:21 AM
  #89
wild_pea's Avatar
wild_pea
hmmm im not so sure because every site i see says RWD model only etc...can anyone confirm?
Old Feb 1, 2014 | 01:27 AM
  #90
EnYcee-G's Avatar
EnYcee-G
I'm assuming that your wheels are flush with the fender correct? If so then no need for spacers? I don't want to go the spacer route to get the flush look.
