Help! Stiff steering wheel
Old Oct 18, 2013 | 03:37 AM
G37slove100's Avatar
G37slove100
Hello there , the other day I was doing a couple of donuts but after i finish , my steering wheel started getting hard and really stiff when i slow down i can barely move it . also when is in neutral it locks i cant even move it
what could be the problem
is a 2008 infiniti g37 6mt about 66,000 miles thanks
Old Oct 18, 2013 | 08:13 AM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
Obviously your car had an erection from all those sick donuts.
GoFightNguyen
Because Racecar
Check your power steering fluid, and your steering knuckle/steering rack.
Old Oct 18, 2013 | 09:07 AM
Weaverama's Avatar
Weaverama
Stiff steering wheels and Flappy Paddles?!?! What's next?
Old Oct 18, 2013 | 09:53 AM
Important questions: Did you hit or run over anything while hooning? Do you have the lower splash shield in place under the engine?
Old Oct 18, 2013 | 11:50 AM
BLamb's Avatar
BLamb
Sounds like you damaged the power steering system. It's really hard on the system when you have the wheel fully locked left or right. Hopefully it just needs fluid and the actual rack isn't damaged.
Old Oct 18, 2013 | 02:31 PM
rmfnla's Avatar
rmfnla
Doing donuts...
Old Oct 18, 2013 | 02:37 PM
Q8y_drifter's Avatar
Q8y_drifter
If the stiffness was temporary I'd say you overheated the P/S fluid and the steering should go back to normal after cooling down. But if its stiff and locked till now I'd say something's damaged.
j50ny
Jul 21, 2017 10:46 AM
kavcheung
Jan 22, 2016 02:40 PM
OneSickBlackG
Jan 6, 2016 08:49 AM
Sylo
Sep 3, 2015 08:27 PM
