A/C not working properly
Old Oct 8, 2013 | 07:59 PM
Calee's Avatar
Calee
Hey guys, new to this forum, I searched almost everywhere for this question but to no luck, no answer. I recently got an aftermarket alarm for my 2011 G37 Coupe Journey, and everything works fine and all EXCEPT the fact that when i adjust the temperature **** up past 61 it starts heating up like it got set to 80 degrees. I live in Florida so, I don't think it should be heating up so quick, related to the issue is when I turn off the a/c and turn it back on it starts blowing at my feet and takes in fresh air as if it were set to default with those modes for some reason. Anyone ever experience anything like this? Should I just take it to the dealer?
Old Oct 8, 2013 | 09:53 PM
Varjo's Avatar
Varjo
To answer your questions: nope and yes respectively.
Old Oct 10, 2013 | 05:55 PM
rmfnla's Avatar
rmfnla
Did you install the alarm yourself?
Actually, it doesn't really matter because if you did you probably need the dealer to help you figure out what you messed up, and if you didn't you most likely won't want to take it back to the monkeys who screwed it up for you...
Old Oct 10, 2013 | 06:13 PM
gizmo134's Avatar
gizmo134
Id check the air tube that goes to the sensor. They probably had the lower dash off, and forgot to reconnect it (or the sensor itself). Should be behind a small grating on the lower right hand side of the dash under the steering wheel
Old Oct 12, 2013 | 08:46 AM
chairman25's Avatar
chairman25
Agree, the alarm installer probably did not put it back together correctly or broke something, or both. Take the car back to the installer, let them fix it.
Old Oct 14, 2013 | 01:53 PM
Calee's Avatar
Calee
Thanks. this was actually the fix. They just forgot to plug in the sensors and a few cables under neath the steering. Quick 1 minute fix.
Old Oct 14, 2013 | 04:08 PM
rmfnla's Avatar
rmfnla
Cool; good call, gizmo134!
j50ny
Jul 21, 2017 10:46 AM
TheIvoryG
Sep 23, 2015 02:06 AM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
ZachThomas
Sep 3, 2015 01:40 PM
