Battery
Old Jul 27, 2013 | 04:10 PM
inyquest's Avatar
inyquest
Battery
Is one car battery better then another?
Old Jul 27, 2013 | 06:03 PM
2008G-Man's Avatar
2008G-Man
Yes .......
Old Jul 27, 2013 | 09:59 PM
Had good luck w/ Interstate batteries FWIW.
Old Jul 27, 2013 | 10:18 PM
Gio37's Avatar
Gio37
Originally Posted by 2008G-Man
Yes .......
Old Jul 29, 2013 | 04:50 PM
2008G-Man's Avatar
2008G-Man
Sorry, I had to answer his question the way it was asked .... I like my Red Tops. Have heard good things about Interstates as well. I always used to go with top of the line Die Hards but looking back, they didn't last as long as they should have given the cost factor.
Old Jul 29, 2013 | 10:28 PM
monytx's Avatar
monytx
I'd opt for Optima batteries like g-man. Had a yellow top in my maxima and I loved it.
Old Jul 29, 2013 | 10:39 PM
inyquest's Avatar
inyquest
Optima batteries seem like a good choice.
Maintenance-free:
Is there really a difference between the Red and Yellow?
Would the car really know the difference?
Is replacing one quick and easy pop in and pop out with all the tech in the car
Old Jul 30, 2013 | 06:24 PM
rmfnla's Avatar
rmfnla
What was good about Die Hards was Sears backed them up "no questions asked" and there was a Sears in every town, so you were always covered.
Not so anymore...
Old Jul 31, 2013 | 11:48 PM
RA081224's Avatar
RA081224
Maintenance-free:
Red tops are standard maintenance free.
Yellow tops - Provides better return from deep cycle discharge and respond better to repetitive discharge charge cycles. Used in vehicles with large stereo installs or aftermarket electronic equipment
Blue Tops - Provides longer discharge times for marine use
Will the car know the difference? Not at all, unless the battery is dead
Old Aug 1, 2013 | 12:13 AM
RA081224's Avatar
RA081224
The short answer is yes but before investing money in a new battery, ask yourself what you expect and what you need. For standard start your car in hot/cold/humid weather, Interstate is hard to beat. Maintenance free is another choice. I've had excellent experience with Optima yellow tops.
If you want to get to the nitty gritty, the three figures to look at are CCA, reserve capacity and the ampere-hour rating.
CCA tells you how much umph the battery will provide on cold starting. Large high compression engines starting in sub-zero weather require high CCA ratings; whereas your G sitting next to the beach does not.
Reserve capacity will give you an idea how long the battery will last on a continuous drain. This tells you how long you can leave those accessories turned on without the engine running and still have a prayer of starting the car again
The ampere-hour rating tells you how much energy the battery can store. More is better but it comes at a price, Generally speaking, emergency vehicles, police cars and motor homes go for the high ampere-hour batteries
MrRiv
Sep 29, 2015 04:59 PM
dedmanchan
Sep 24, 2015 11:25 PM
AMCDeac
General Tech Questions
Sep 19, 2015 05:25 AM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
TVPostSound
Sep 2, 2015 04:09 PM
