HELP Need opinions
Hey guys,
So I've got a 2008 G37s which is mostly stock. (Sub Installed/LED's in grille/Windows Tinted)
I've got about $400 I'm willing to spend on it and I'm debating between what I should get (Preferably Lowered or Exhaust)
Any Ideas???
(What my car basically looks like atm)
Any Ideas???
With that budget you can go springs... not much options on exhaust ... Tanabe axel backs are still in the $7-800 range...
I have a set of Stechs Tein sitting in the garage with oem struts if your interested... low millage on both... sitting there ready to be shipped!
How much did you lower them? How much was it? Does your car ever scrape? I was looking into H&R Lowering Springs they lower: Front 1.2" and Back 0.8"
H&Rs rarely lower what they claim, it's typically one of the lowest spring drops for the G. You'll probably blow your $400 budget since you'll probably need F&R camber kits (about $500 more). Maybe H&R has another part # for that mild drop but all H&Rs I've seen are pretty slammed. Might want to look into Blairs' STechs, if they're already on the OEM struts that would save some install time and you'll be able to keep your stock springs on your stock struts should you ever want to go back to oem height or at the very least have another set of struts as a spare. S Techs are pretty low too, lower than Eibachs but usually not as low as H&Rs.
The ride is a little stiffer but I like the handling feel.
g/l
Tuckermaclain
Oct 5, 2015 11:41 PM
Z33_SPL
Sep 29, 2015 07:52 PM
Slapshot1
Sep 27, 2015 08:40 AM
