Roadside Assistance Cost?
Old Apr 28, 2013 | 08:44 PM
Stay Frosty's Avatar
Stay Frosty
Question Roadside Assistance Cost?
Anyone know the approximate cost of having roadside assistance unlock my car and jump start it? I'm out of warranty.
Is there any way I can unlock it myself? To my surprise the mechanical key doesn't even unlock it. I guess the locking system is not so mechanical. Why they would design it that way is beyond me...
Appreciate any advice!
Old Apr 28, 2013 | 08:46 PM
NJ Torque's Avatar
NJ Torque
If under 4/60 its no charge...
Edit, seen your out of warranty... maybe theyll be stupid and not charge you.
Old Apr 28, 2013 | 10:14 PM
jaykellogg's Avatar
jaykellogg
Can you get underneath and hook up a battery charger? Plus on the starter and neg on the chassis.
Old Apr 29, 2013 | 12:55 AM
TVPostSound's Avatar
TVPostSound
Good idea!!
Old Apr 29, 2013 | 09:05 AM
jmann's Avatar
jmann
Does the mechanical key work on the trunk? It should be able to unlock any of the keyholes, that is your fail safe.
Old Apr 29, 2013 | 10:16 AM
Stay Frosty
As far as I know the trunk doesn't have a keyhole. Just the little chrome button on the tail light to pop it open.
The only keyhole I see is on the drivers door and it doesn't work. The lack of resistance tells me that it's not mechanical. Seems like a pretty huge design flaw to me. Are all modern cars like this?
Old Apr 29, 2013 | 10:21 AM
TVPostSound
The key lock is mechanical, using double steel cables.
Old Apr 29, 2013 | 11:03 AM
jmann's Avatar
jmann
I guess I never noticed that about the trunk. It sounds like someone may have tried to break into your car at some point and broke the lock cylinder, which would be why that isn't working.
Old Apr 29, 2013 | 12:50 PM
Stay Frosty
There was a quote on another forum where somebody said that the mechanical key unlocks the door by sending a signal to the BCM, according to the FSM. Dunno how truthful that is, but he had the exact same problem that I did and had to get roadside assistance to come.
How hard is it to access the starter motor? If I attach a jump starting unit to it, will that be enough to open the door?
Old Apr 29, 2013 | 01:02 PM
Stay Frosty
Do you think Geico can unlock it? I do have roadside assistance with them on my insurance plan. Or is this a special situation which only Infiniti will know how to deal with?
Old Apr 29, 2013 | 01:05 PM
hechen507's Avatar
hechen507
I wouldn't try this if I were you... Connecting a direct power source to the starter motor will crank the engine. And a starter motor can draw over 300amps, most battery charges only supply a few amps, thus you will probably blow the battery charger. You want to connect the (+) to a source before the relay for the starter motor, basically as close to the battery as possible in the circuit.
I starter motor is just a motor, if you connect a power to it it will turn, regardless if the car in unlock or key is in place. Rather the car will start is another matter, probably not, the ECU will probably cut fuel and spark if the key was not present.
Old Apr 29, 2013 | 01:27 PM
quakerroatmeal's Avatar
quakerroatmeal
Why not call Geico or Roadside Assistance and ask them? Is your car stuck at home? I'm not sure how the G's hood latch is routed. But on a lot of cars you can get to the cable through the fender well on the driver side.
Old Apr 29, 2013 | 10:05 PM
Stay Frosty
Geico took care of it free of charge.
Thanks guys.
Old Apr 30, 2013 | 07:28 AM
jaykellogg's Avatar
jaykellogg
Actually - no. The starter has a heavy wire connected directly to the battery and a "regular" wire connected to the starter relay. If by some chance you connected a + to the wire going to the starter relay, the solenoid would engage, but the starter would not rotate. If you connect to the heavy wire, then I would immediately try the smart key to unlock the door.
Glad you got it open without cost.
Upscale Speed
Dec 26, 2015 08:45 AM
conkus805
ECU Tuning / Dyno Data
46
Nov 19, 2015 07:49 PM
parkern
Oct 1, 2015 10:15 PM
dedmanchan
Sep 24, 2015 11:25 PM
