G feeling a little slower than normal...?
Old Feb 15, 2013 | 12:59 PM
GTLAW's Avatar
GTLAW
I have intake and CBE no Tune! and I love it! I did not even reset my ECM when I installed the intake or CBE. Just let the car tune it self, took two weeks but the ECM will adjust!
Old Feb 18, 2013 | 03:57 PM
bmbweber's Avatar
bmbweber
Today i picked up some injector cleaner. My bro was told by someone that Seafoam injector cleaner works good, but the guy at the store told me it tends to eat away at o-rings so I picked up this lukas oil injector cleaner.
I also picked up some throttle body cleaner and going to see if i have time to clean them out tomorrow. Any other tips? Im just worried it might have something to do with my tune and really don't feel like having to pay to have it retuned.
Old Feb 27, 2013 | 07:14 PM
bmbweber's Avatar
bmbweber
Okay, so after that, no change. It's not that the car isn't running correctly, it seems as if its not putting down the same power.
So to add to the story, my SES light came on and coded to be O2 Sensor 1, Bank 1. I got home and peeked under the hood and under the car, and I also noticed the exhaust manifold cover on bank 1 (passenger side) is cracked almost in half (Split right across the air/fuel sensor, but this sensor seems not to be damaged). So now my question are:
1.) Is the exhaust manifold cover covered under powertrain warranty, keeping in mind aftermarket test pipes/exhaust?
2.) Could a bad O2 sensor cause this decrease in performance?
3.) I really feel like if I could put it back on the dyno, that could answer my questions, BUT I'd rather not pay another $500+ to have a dyno/retune if it turns out not to be the problem. What are some opinions?
Old Feb 27, 2013 | 07:21 PM
JohnsVert's Avatar
JohnsVert
I could answer number one for you. Im pretty sure the dealer wont warranty your exhaust manifold after seeing the aftermarket exhaust and test pipes. Best thing to do is put back everything stock to avoid any scrutiny.
Old Feb 27, 2013 | 07:43 PM
bmbweber's Avatar
bmbweber
I figured, but even the upper cover?
Old Feb 27, 2013 | 07:46 PM
DeamonG37s's Avatar
DeamonG37s
Its not misfiring? Is it winter where u are?
Replace the manifold with stockies or upgrade the headers. Something caused the manifold to break. Either winter conditions I doubt or stuck valve etc or a heavy foot in that case pay the stupid tax.
Call the dealership before you remove parts to see if your eligable in the first place. Either way manifolds gotta come off. I don't think a weld will hold it. Could be jus a crack, or internal damage. GL
Old Feb 27, 2013 | 07:52 PM
bmbweber's Avatar
bmbweber
No, its not misfiring. Im also not saying the manifold is cracked, just the cover. I doubt the manifold is cracked or damaged because im sure i would hear it coming straight from the cylinders...
Old Feb 27, 2013 | 07:55 PM
bmbweber's Avatar
bmbweber
Also if the manifold was cracked i would be losing all my backpressure resulting in more power loss than im talking about. My car has the power of a stock g37; not one with exhuast, test pipes, intake tubes/filters, and a uprev tune
Old Mar 1, 2013 | 11:35 AM
bmbweber's Avatar
bmbweber
Anyone?? Any help?
Old Mar 2, 2013 | 11:51 PM
john91's Avatar
john91
There is nothing wrong with your car. The way it works is very interesting... If you drive your G for 2-3 days without going high rev, the computer adjusts the fuel ratio and it outputs less power for fuel economy. The easiest way to change it is to reset ecu. However there is another way and its much more fun... Before you want to race someone, floor your car a couple times! It will adjust itself to give more fuel therefore more power
Old Mar 3, 2013 | 10:26 PM
bmbweber's Avatar
bmbweber
But even enough to lose to a stock 09 g37? Even before we raced I was driving somewhat hard for a good 5 mins ...
Old Mar 3, 2013 | 10:58 PM
RISKY GUY's Avatar
RISKY GUY
He means hard driving for a couple hundred miles.
Try 10/15 full highway pulls, in Mexico ( I'm not condoning street racing ) Ecu is adaptive, if you get stuck driving slow, cars reaction is horrible. Let it cool down then run it.
Btw, are you in warm temps, sounds like a oil cooler is in your future,
God luck with your runs against your friend. Or is it possible your friend is lying about being modded.?
Old Mar 4, 2013 | 12:15 AM
hobbs's Avatar
hobbs
Originally Posted by bmbweber
Now that you mention it, i do usually run Shell or BP gas, but recently i switched to gas from Costco because i save $.30-.40... Wonder if it could be from that...
We have a winner!
Old Mar 4, 2013 | 01:07 AM
  #29
MyG37xS's Avatar
MyG37xS
I would agree bad gas could be the issue of not spark plugs.
reachout
General Tech Questions
38
Jun 27, 2020 12:35 AM
vamarris
Dec 9, 2018 11:10 AM
parkern
Oct 5, 2015 12:12 PM
EnYcee-G
Oct 4, 2015 09:27 PM
mikeace
Sep 30, 2015 01:39 PM
