G feeling a little slower than normal...?
Old Feb 14, 2013 | 04:02 PM
bmbweber's Avatar
bmbweber
So lately I've been noticing how my G seems slower in all ranges of power. I used to feel a good amount good power, especially between 4-6k rpm's but lately something is off.
I just raced my buddy in his 09 journey A/T, bone stock, and he pulled on me about half a car length from 40-90. I have a 08 sport M/T with exoticspeed exhaust, gtm test pipes, hps intake tubes/high-flow filters, and a UpRev tune.... ..........
Whyyyyyyyyy??
I was thinking maybe it was because I took the negative off the battery and left it off over night, in order to reset the ecu for my bags because it froze. I thought maybe i reset the tune by disconnecting the negative but this was just last weekend, and I've felt my G to be a little slow these last few weeks.... Anyone had similar experience?
Old Feb 14, 2013 | 04:23 PM
Varjo's Avatar
Varjo
How many miles? You could have old/dirty sparkplugs.
Old Feb 14, 2013 | 04:27 PM
bmbweber's Avatar
bmbweber
I have 41k, and i would bet my buddy even has more than me...
Old Feb 14, 2013 | 04:43 PM
BLamb's Avatar
BLamb
I'd check and clean the air filters, throttle bodies, spark plugs. Could be bad gas, maybe pick up some fuel injector cleaner and run it through as well.
Old Feb 14, 2013 | 04:46 PM
chris5o4's Avatar
chris5o4
shifting too late and fuel cut off happens?
Old Feb 14, 2013 | 04:51 PM
BluestickG's Avatar
BluestickG
id have to agree our Gs throttle bodies get dirty. Clean em out and get some injector cleaner. Clean the air filters and check your plugs
Old Feb 14, 2013 | 04:53 PM
bmbweber's Avatar
bmbweber
I will check the plus and filters, and look into how to clean the throttle bodies. Now that you mention it, i do usually run Shell or BP gas, but recently i switched to gas from Costco because i save $.30-.40... Wonder if it could be from that...
Regardless it seems all too strange to be running like this. Especially losing to my friends bone stock 5A/T!!
Old Feb 14, 2013 | 04:55 PM
bmbweber's Avatar
bmbweber
Elaborate? Basically it just seems to climb the rpm's slower by just enough to notice and with less power. Nothing major but enough for me to notice, and to lose to another stock G
Old Feb 14, 2013 | 04:58 PM
JerseyG37s's Avatar
JerseyG37s
i had a friend that had that same problem.... he had just recently broke up with his girlfriend and was eating a lot gained a lot of weight and thus slowed his g down a lot....
Old Feb 14, 2013 | 05:31 PM
Rad_Slinger's Avatar
Rad_Slinger
wait a second.
did you just call the op fat?
Old Feb 14, 2013 | 05:38 PM
JohnsVert's Avatar
JohnsVert
Lmaoooooooooo
Old Feb 14, 2013 | 05:43 PM
Varjo's Avatar
Varjo
LOLOLOL, but in all seriousness, unless someone gains 50+ lbs, you're not really going to feel it.
Old Feb 15, 2013 | 08:31 AM
IPL 370GT's Avatar
IPL 370GT
This seriously just made me spit my coffee
Old Feb 15, 2013 | 11:21 AM
huwee06's Avatar
huwee06
I have similar mods with UPREV as well, there's days where myG will feel sluggish other days it's back to normal preppy self and it annoys me as fawk. Have no clue what's the deal is maybe like JerseyG37s said ha
Well I need a retune anyway so hopefully it will eliminate this problem. OP talk to your UPREV tuner and tell him your problem maybe he's kind enough to run it on the dyno see if everything is running correctly? I'm sure he can help solve your concern.
Old Feb 15, 2013 | 12:28 PM
PrinceValium's Avatar
PrinceValium
Whyyyyyyyyy??
https://www.myg37.com/forums/d-i-y-i...isconnect.html
