Brake light and vdc turning off while accelerating.
Old Oct 2, 2012 | 01:42 AM
norcalg37's Avatar
norcalg37
Within the last few weeks I started seeing that while accelerating quickly, for example an on ramp to a freeway, the brake light in the instrument panel would turn on and then turn off when I slowed down. This has happened quite often. More rarely I've started to notice there are times where the vdc off light turns on and the slip light stays on. These lights will stay on until the car is turned off and the vdc button is unresponsive. If anyone has any insight on the problem please help.
Old Oct 2, 2012 | 02:36 AM
Skyline6mt's Avatar
Skyline6mt
you just need to top off your break fluid. the sensor is near the front of thencar so when you accelerate the car thinks its out of fluid. fill it up and itll go away
btw there are already a few posts on this try searching first next time.
Old Oct 2, 2012 | 01:52 PM
norcalg37's Avatar
norcalg37
Does that also explain the vdc turning off?
Old Oct 2, 2012 | 04:39 PM
RISKY GUY's Avatar
RISKY GUY
Yes it does, its to get your attention.
Looks like it worked, just refill/flush brake fluid depending on total miles.
Plus sounds like you drive hard
pal51961
Jan 16, 2016 08:26 AM
Twista
Aug 30, 2015 12:23 PM
MJ HINX
Aug 23, 2015 10:30 PM
Skeletor06
Aug 2, 2015 12:54 AM
