a/c recirculates automatically ?
Old Jun 19, 2012 | 03:31 PM
enronforme's Avatar
enronforme
The ocd is kicking in hard now! Here's one that's been bugging me for a month now.
When I turn the a/c on, it automatically switches to recirculating air, which I hate! I have to manually switch it back over to outside air (when I remember to look down). Is this standard? Any way to change it in the menu that I've missed? it's not a big deal- just a pain in the ***.
Thanks in advance for helping alleviate my ocd!
Old Jun 19, 2012 | 03:43 PM
DashKid's Avatar
DashKid
That is normal because it is to hot inside your car and it tries to cool down. Once the A/C see that in the interior of the car is the same as the temp set it will change.
You can test this out by turning the a/c and moving the temp dial hotter and you will see it change. very normal.
Old Jun 19, 2012 | 04:19 PM
nickw's Avatar
nickw
I notice that happen to me if I go below 70 C on the air . It will automatically switch to recirculate .
Old Jun 19, 2012 | 05:04 PM
stickstickly's Avatar
stickstickly
What do you guys normally set your temp to? I don't mean to complain, but i think the ac in mine works a little too well, the thing freezes me out as soon as i turn it on!
Old Jun 19, 2012 | 05:11 PM
DashKid's Avatar
DashKid
mine is on 75.
Old Jun 19, 2012 | 05:12 PM
Rad_Slinger's Avatar
Rad_Slinger
Usually set mine to 65 initially then turn it down to 70ish.
Depending how hot it is.
Old Jun 19, 2012 | 05:20 PM
DashKid's Avatar
DashKid
Lmao mattster. How can 65 go down to 70. Silly goose is silly.
Old Jun 19, 2012 | 05:43 PM
nickw's Avatar
nickw
Well, technically hes turning the air down , the number is just going up . I usually put mine between 60-75. 70-75 normally and when its hot as ***** ( mid florida (so almost every day)) its at 60 .
nukee26's Avatar
nukee26
It's more efficient to recirculate the air in the cabin. So I'm assuming that's why it does that.
Old Jun 19, 2012 | 05:49 PM
DashKid's Avatar
DashKid
Hush. Hotter probably in TX than FL and mine is on 75 cause if I put it on 60 I get cold like in 10 mins.
Old Jun 19, 2012 | 06:13 PM
Chekov's Avatar
Chekov
Senior Citizen
I may be wrong, but I always thought the system first goes to recirculate whenever the outside air temperature is greater than the inside setting. This is in order to cool down the inside a bit faster rather than letting in very hot air.
On similar note, when starting out on a hot day with an inside temperature of 130 degrees or more, I open both windows as I drive off until it comes down to a tolerable level.
Old Jun 20, 2012 | 09:35 AM
DashKid's Avatar
DashKid
You are correct sir. Don't want hot air to come when its 100+ degrees outside.
Old Jun 20, 2012 | 01:09 PM
enronforme's Avatar
enronforme
Great comments- makes sense now that I think about it, as I almost always leave the a/c set on 60 and turn it on or off manually (not big on climate control). Thanks!
jfisher
General Tech Questions
Nov 2, 2015 07:51 AM
Amaadkhan2k
Oct 11, 2015 11:52 AM
arkyv714
Oct 4, 2015 03:44 PM
Sep 25, 2015 01:38 PM
Rob Cooper
Sep 14, 2015 01:57 PM
