Car beeping
Old May 8, 2012 | 01:57 PM
Sarah Brown's Avatar
Sarah Brown
Car beeping
I am new to my 08 G37S and am wondering why the car beeps every time I shut it off and get out. Although occassionaly it doesn't. Can anyone shed some light onto this?
Old May 8, 2012 | 02:05 PM
reVx's Avatar
reVx
If you manually unlock the doors before you turn off the car, I've noticed it does it. Also when you leave the keys in the key holder (bottom left of steering column) after you turn your car off and open the doors it will do it as well. It's basically making sure you don't leave your keys in the car or keep it unlocked on accident.
Old May 8, 2012 | 02:28 PM
SwissCheeseHead's Avatar
SwissCheeseHead
If your headlights are on and you turn off the car, it will beep at you as well, but will stop once you close the door and the light turns off.
Old May 8, 2012 | 03:05 PM
2008G-Man's Avatar
2008G-Man
I've noticed if you open the door too quickly after shutting it off it will beep. Wait a second or two until it all powers down and locks the steering before opening the door (and take the key with you).
Old May 8, 2012 | 09:41 PM
hywel's Avatar
hywel
Mine does the same thing too and I'm damned if I can figure out why! I'll check out the waiting thing...thanks for asking, glad I'm not on my own!
Old May 8, 2012 | 10:07 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Does the steering even lock on the manual cars?
Old May 8, 2012 | 10:27 PM
SkylineAWD's Avatar
SkylineAWD
It can, because mine has done it.
Old May 9, 2012 | 10:53 AM
jesse550's Avatar
jesse550
I believe if your headlights are on auto and you open the door it assumes they are "on" and beeps until you get out and shut the door. I'll do some experimenting and comment back on this.
Old May 9, 2012 | 11:53 AM
Mayu's Avatar
Mayu
Correct, if you have something ON, you will get an alarm.
However, if the OP is certain that nothing is ON, I too have experience this and was unsure to cause until a recent issue of Car and Driver had an article on "Why your Car Does that".
For theft reasons, the IIHS mandated anytime the driver opens the Drivers door with the keys in the ignition an alarm must sound. This obviously does not apply to Push Button ignition systems, however the IIHS has not revised this law and manufacturers must have an alarm. So, with Push Button equipped vihicles, if you open the drivers door and then turn OFF the ignition, the alarm will sound. I have tested this on both my G and IS both with Push Button. If I shut the ignition OFF then open the door, no alarm. Open the Door then shut her down, Alarm... voila.
C&D does not explicitly state this in their article, I am reading between lines here... anyone can correct me.
Cheers.
Old May 9, 2012 | 12:02 PM
jmueller's Avatar
jmueller
Also, if you are working on your car, and the beeping is driving you crazy, try closing the door and opening it again. The beeping will stop.
Old May 9, 2012 | 01:48 PM
2008G-Man's Avatar
2008G-Man
Cheers.
If you shut the car off and open the door as things are winding down it will sound, if you wait a second or two for everything to completely shut down it won't sound. There is a fine line between the time you push the ignition button and the time everything is truely off.
Old May 9, 2012 | 03:33 PM
DashKid's Avatar
DashKid
Cheers.
That is correct. Totally forgot about that, if you turn off the car with the door open it will start beeping so that you won't forget your keys in your car.
Old May 9, 2012 | 05:17 PM
G37S-OONER's Avatar
G37S-OONER
Chicks man......
Old May 9, 2012 | 05:37 PM
DashKid's Avatar
DashKid
Originally Posted by G37S-OONER
Chicks man......
I don't know man. The OP has been asking some weird azz questions and that's all she did was ask questions. Not posts no thing and my gut feeling is telling me this might be a dude just acting like a girl. AKA troller like you sooner .
Old May 9, 2012 | 06:07 PM
G37S-OONER's Avatar
G37S-OONER
