Hard to fill gas tank
Old Feb 27, 2012 | 03:25 PM
babyxgk17's Avatar
babyxgk17
I'm having trouble filling up my gas tank, i think it's only filling up to 10 g. What should I be telling my mechanic to fix? Also, there's some gas residue near my gas tank, what should I use to clean it. Doesn't seem to come off with just water and a good wipe.
Old Feb 27, 2012 | 11:21 PM
v.b's Avatar
v.b
have you tried taking it to the dealership first?
Old Feb 28, 2012 | 12:17 AM
xxg00w0's Avatar
xxg00w0
it should be 15 gal!
Old Feb 28, 2012 | 12:18 AM
mtrsprt's Avatar
mtrsprt
Try a different pump? Make sure the nozzle is in all the way, and don't try to "TOP OFF" more than $.25
Old Feb 28, 2012 | 02:31 AM
chasemyaccord's Avatar
chasemyaccord
Actually it should be more like 17 gallons (assuming you're almost on E). My last fillup was over $70 and it's only going to get worse
But I had your same problem before. They replaced my fuel sensor and it hasn't happened since. Just take it to the dealer and they'll know what's up.
Old Feb 28, 2012 | 10:12 AM
apexi350z's Avatar
apexi350z
so does the pump stop at 10 gal, even though it's empty? or you can't really tell how much gas is in the tank, and it top off at 10gal?
if it's the first one, then it may be your fuel gauge...
linvbro
Aug 22, 2016 01:25 PM
2K1 6T8
Oct 6, 2015 07:40 PM
MrRiv
Sep 29, 2015 04:59 PM
si_driver
ECU Tuning / Dyno Data
24
Sep 29, 2015 11:38 AM
VIVID
Sep 27, 2015 09:45 AM
