Has this happened to anyone?
Old Sep 26, 2011 | 08:59 PM
emunoz's Avatar
emunoz
I lost my tail lights, My brake and blinker lights work but the running lights wont turn on... I also noticed my volume and temperature lights went out also but no fuse is blown that I can find. Does anyone know or had this happen to them? I assume I will have to replace complete tail light housing?
Old Sep 26, 2011 | 09:33 PM
Weiboy718's Avatar
Weiboy718
no! your illumination fuse is burnt, the fuse box for that is next to the battery box. you have to remove the battery cover held on by 4-5 clips. you can use a flat head screw driver and pick it then pull it out. after that there's a panel that covers part of your windshield, remove that also then right next to the battery closer to the fender side you'll see a big black box. pull it out and look for "ILLUMINATION OR BRAKE ILLUMINATION". put in a new fuse and you should be good to go. you should have extra fuses under the drivers side fuse box on your kick panel.
if for some reason you put a new fuse on and it blows right away, check back in here and i'll guide you over on what to do again. i have a feeling it's going to pop once you turn on your lights, fuses usually don't burn out for no apparent reason.
good luck! oh yeah, the same exact thing happened to my friend and it took me awhile to troubleshoot the short
Old Sep 26, 2011 | 10:22 PM
emunoz's Avatar
emunoz
Is this the long-er black box right next to the battery? Its two rows wide or is there another in the battery box?
Old Sep 26, 2011 | 10:46 PM
Weiboy718's Avatar
Weiboy718
you need to remove all the panels to see the long black box. there's no letterings or anything on there. trust me dude! get all them panels off and you'll see it!
Old Sep 30, 2011 | 08:53 PM
emunoz's Avatar
emunoz
Nothing in that box to do with ilumination. Only main relays, I think It's a wireing issue I have to take it in to infiniti. Unfortunately I am in Devils Lake, ND and I haven't a clue on where the nearest dealer is or when I'll have time to make it in there. Thank you all for the help though much appreiated
Old Sep 30, 2011 | 09:02 PM
Weiboy718's Avatar
Weiboy718
do you see a series of fuses inside of the big black box??? if not you didn't follow the instructions. okay, did you installed any leds recently? like license plate light, reverse lights
Old Oct 1, 2011 | 04:31 AM
adroitcaptor's Avatar
adroitcaptor
It amazes me why people to not listen to good advice even when given by a considerate and helpful individual. Weiboy is exactly correct...
fuzzed
Aug 21, 2020 09:35 AM
linvbro
Aug 22, 2016 01:25 PM
parkern
Oct 1, 2015 10:15 PM
ajosowiecky
Sep 30, 2015 12:15 PM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
