Rattling Noise
Old Jul 24, 2011 | 07:57 PM
Soliditude's Avatar
Soliditude
Everyone gets a rattle there, I swear! I also, rarely, but sometimes get it. I Had the dealer dig around within the door panel, but it wasn't gone. Shortly after, I found out that it was the seatbelt dispenser. You know how it clicks when you put it all the way up and make it stay there? Fiddle around with that and make sure it's clicked in the up direction, not lowered. Also, play around with the seatbelt port as well. Fiddling around with those seemed to make my rattle go away. Also, check the seatbelts in the rear and make sure that they are solidly placed. If they have leeway of movement, they will rattle at higher cruising speed.
The next G better be freakin' completely rattle-less! Our old '97 Camry has less rattles.
Old Jul 24, 2011 | 10:02 PM
jblyden20's Avatar
jblyden20
Ok everybody. Was driving my G today on I95 and the noise is constantly there at 80 mph. It sounds like its coming from two places, the passenger rear and the passenger side door. I'm hoping that it's the speakers. Has anyone had any issues with their speakers making this noise? PLEASE HELP! This noise is so annoying when I'm driving and on the phone with someone. Does anyone think that there is some kind of issue with the bluetooth handsfree and the speakers because it more noticable when I'm on the phone with someone? If anyone has any info for me let me know, because i'm actually thinking about trading my car in because of this.
Old Jul 25, 2011 | 05:09 PM
SpinG37X's Avatar
SpinG37X
From reading the various rattling posts, all signs show to that good old seatbelt. What you mention is something I need to check. It is very similar sound to that clicking sound you mention, but more coming from lower rear side (inner pannel)....
Old Jul 25, 2011 | 05:21 PM
cruzmisl's Avatar
cruzmisl
I hear a weird tin-can-ish rattle on the pass side. Not sure what it's from. Definitely not the seat belt.
Old Jul 26, 2011 | 05:55 PM
bluecoupe's Avatar
bluecoupe
Check the rear seat catch
Old Jul 26, 2011 | 08:34 PM
purplelittlegg's Avatar
purplelittlegg
if i take my car to dealership, will they found out the problem?? i tried once before but they test drove my car for 60 miles and did nothing = =
Old Jul 27, 2011 | 02:20 PM
ooranzoo's Avatar
ooranzoo
You may want to double check the seatbelt component. Because, just like you I had the similar issue and the dealership took off my dash and put foam in the parts they thought was causing the rattling noise. In addition, they suspected it might come from the passenger side speaker area. But after researching this night and day, I found that the problem was in the seat belt mechanism. In my case, whenever I drove over 50-60mph that annoying rattling noise kept coming back. So, when it happens to you, try to push the female seatbelt component thats located between the center console and passenger seat. Push it towards the passenger seat and see if the noise goes away. If so, there is a loose part in the seat belt assembly that is causing the rattle. Hope this helps.
Old Jul 27, 2011 | 07:52 PM
SpinG37X's Avatar
SpinG37X
Good advice, i have similar problem only when accelerating. Need to check this out.
Old Jul 28, 2011 | 01:07 AM
voltic's Avatar
voltic
Originally Posted by tbone12
Could it be the passenger side seatbelt rattling against the inside of the car. I've noticed this before in my car
THIS. It drives me batsh*t if nobody's sitting next to me until I remember to reach over and lift the arm a little so it hangs toward the front of the car.
Old Jul 28, 2011 | 08:30 PM
SpinG37X's Avatar
SpinG37X
Originally Posted by voltic
this. It drives me batsh*t if nobody's sitting next to me until i remember to reach over and lift the arm a little so it hangs toward the front of the car.
fuzzed
Aug 21, 2020 09:35 AM
Rybitron
Nov 18, 2015 03:11 PM
si_driver
Oct 1, 2015 09:53 AM
Msherburneg37xs
Intake and Exhaust
Sep 30, 2015 06:39 PM
MrRiv
Sep 29, 2015 04:59 PM
