08 coupe bumper swap with 2011 sport bumper INFO.***
Old Mar 16, 2011 | 01:05 PM
  #31
jjasonSU's Avatar
jjasonSU
Boy, some people need it broken down into 1+1 :-/
Anyway, I wanna see what it looks like man. Good luck.
Old Mar 16, 2011 | 09:18 PM
  #32
jjmont17's Avatar
jjmont17
your not doing the breaking down so , some people just want to get their info straight
Old Mar 16, 2011 | 09:34 PM
  #33
Doggy's Avatar
Doggy
300 per fog!? That's crazy! I wuda just got An authentic ts kit, but this should looks good, can't wait to see final pics!
Old Mar 16, 2011 | 10:17 PM
  #34
P Casey's Avatar
P Casey
Yurp, I thought about that but decided to go a different direction. Trying something a little different. Yeah 300 per fog is bonkers, i ended up getting them fur 170 from onlineparts. The 2 faux grilles have holes in the with the chrome around them in which the fogs match up perfectly with the holes as well as the washer fluid tank, so it would be hard to make it look right with a different aftermarket fog. should be done tomorrow
Old Mar 17, 2011 | 12:36 AM
  #35
Chekz's Avatar
Chekz
OP aren't the middle vents the same as the old sport bumper?
Old Mar 17, 2011 | 12:39 AM
  #36
P Casey's Avatar
P Casey
nopers, they are off by an inch
Old Mar 17, 2011 | 01:56 AM
  #37
simpson_G37X's Avatar
simpson_G37X
so if you buy the '11 bumper, make your own mesh, dont want the foglights (as much as i do i want the fogs down low ), you could run the 11 bumper with no accessories?
Old Mar 17, 2011 | 02:08 AM
  #38
P Casey's Avatar
P Casey
pretty sure, remember my car is an 08 sport and I have the 11 sport bumper. I cant confirm that this will fit on a 08-10 non sport, nor can I can confirm that the new IPL bumpers fit. Most likely everything should be direct fit. But yes if you have a sport bumper now and want to buy a 2011 sport bumper and make your own mesh that would be all you would need. You will also have to paint it.
Old Mar 17, 2011 | 10:56 AM
  #39
simpson_G37X
ok great thanks. i read somewhere on here a while ago someone with a non-sport bought a sport bumper and it worked. its the exact same front end, i dont see why the mounts would be in a different place. then again i have the AWD. guess il find out when i take my bumper off for the Gen3 lol
and PS its thursday
Old Mar 17, 2011 | 11:16 AM
  #40
CDONNS's Avatar
CDONNS
Originally Posted by breftayka
Screw a washer tank. I don't think I've used mine since I've had it lol.
Don't know the dimensions of the new bumper in that area but you could even just heat up the original tank and remold it a bit when it's soft. Just an idea...could save some $$
Old Mar 17, 2011 | 02:37 PM
  #41
myk1013's Avatar
myk1013
Thanks for the info man. I was considering this for a while but it may not be feasible for me anymore.
My question is, how would you wire the foglights? and will it have a seperate switch?
Old Mar 17, 2011 | 02:44 PM
  #42
P Casey's Avatar
P Casey
nope, they are going to be wired in to the main lights switch, so all you have to do is turn your normal headlights on, same switch.
Old Mar 17, 2011 | 03:43 PM
  #43
P Casey's Avatar
P Casey
and PS its thursday
Yup, probably not getting it back until tomorrow now. We have to wait for a part, we need a pigtail to hook up with the foglights to make them run off the main switch, and infiniti only sells the whole wiring harness which is expensive so we might switch out the bulbs or see if we can find a pigtail that works
Old Mar 17, 2011 | 09:24 PM
  #44
P Casey's Avatar
P Casey
Bumper part# 620221NL0H this is 2011 coupe sport bumper cover unpainted
Old Mar 18, 2011 | 04:24 PM
  #45
P Casey's Avatar
P Casey
cars ready going to p/u today after work. Does anyone know what pigtails could work for the 2011 stock fogs??? Or suggestions on different bulbs for the fog lights????
Topher9425
Dec 1, 2015 03:00 PM
bikerjosh
Aug 19, 2015 11:26 PM
Rybitron
Aug 10, 2015 10:21 AM
350zrunnin12s
Aug 9, 2015 09:55 PM
