Inside air recirculation with a/c compressor off possible?
Old Dec 7, 2010 | 11:59 PM
hoofhearted's Avatar
hoofhearted
You're right. Oh well. They made it too smart for our own good.
Old Dec 10, 2010 | 10:41 AM
mossman's Avatar
mossman
I never quite understand why people get so annoyed that the AC light is on. The AC might not be running if it is below freezing... even if the light is on.
On a side note, it is good that the AC runs a lot. Studies have found that there are less AC issues now that Auto systems use the AC a lot. The reason for this is because when your AC is running, so is the lubricant that keeps all the seals lubricated.
Its when people only run their AC a couple times a year they have issues. Just ignore the light........
I don't even want to hear about gas mileage savings with AC off. This car is not great on gas to begin with!!
Old Dec 10, 2010 | 12:35 PM
Skilled's Avatar
Skilled
no just when you want to not smell bad order from the outside and you press the button the a/c also come on and then you have to re-adjust the temp. so your comfortable again!
Old Dec 10, 2010 | 11:25 PM
briann510's Avatar
briann510
Exactly. Feeling the a/c hit you instead of heat and then having to re-adjust is kinda not right. I mean its just one of those stupid things that irritates some people like me cause they got nothing else to bitch about while driving cept annoying drivers driving the speed limit.
Oh and onother thing, the read window defroster doesnt work worth a damn either. It takes like 15 minutes to clear the back window of inside fog or outside dew. Hell my daughters 8 year old POS Neon clears the back window in 3 minutes.
Im glad this is my wifes car cause I really dont like much about it plus its just too damn slow.
Old Dec 11, 2010 | 12:36 AM
JohnEnglish's Avatar
JohnEnglish
My defroster clears the window in about a minute. If it's taking that long just to clear fog or dew you should take it to the dealer.
Old Dec 11, 2010 | 12:49 AM
G37SBS's Avatar
G37SBS
i'm having the same issue with OP .. so if this problem solved or We have to drive it with AC light on in this winter when the heat is on?
Old Dec 11, 2010 | 04:56 AM
briann510's Avatar
briann510
Yup...very stupid way of getting heat with a/c compressor running re-circ inside air and I always use inside recir in all our vehicles when driving them. I dont care what the reasoning is, its a stupid way of doing it.
Im surprised the designers didnt have the heat have to come on when the a/c is on as well on a 100 degree day...
Old Dec 12, 2010 | 07:18 PM
ColaBear's Avatar
ColaBear
turn off the fan, press the recirculation button, and turn on the fan again, there you go.
Old Dec 12, 2010 | 08:03 PM
JohnEnglish
Why wouldn't you want the A/C on? I've always keep it on in the winter otherwise the windows on whatever vehicle I'm driving start to fog up in a minute or two.
Old Dec 13, 2010 | 09:21 AM
s2ktoEvo's Avatar
s2ktoEvo
I don't know where you live, but on a 20 degree day the air around here is dry enough to make you into a mummy. I don't need a dehumidifier on those days.
Old Dec 13, 2010 | 05:15 PM
briann510's Avatar
briann510
Knock knock....anyone home....
IT DOESNT WORK!
Old Dec 14, 2010 | 05:12 PM
ColaBear's Avatar
ColaBear
IT DOESNT WORK!
Mine works, I don't know is it because mine is a Canadian model.
Old Jan 3, 2013 | 12:00 AM
murat's Avatar
murat
https://www.myg37.com/forums/2693335-post9.html
37
Oct 17, 2020 11:12 AM
vamarris
Dec 9, 2018 11:10 AM
BurtoN86
Sep 30, 2015 03:32 AM
SheLLz
Sep 24, 2015 08:02 PM
