Hood off centered
Old Oct 15, 2010 | 02:39 PM
pcwd's Avatar
pcwd
Hood off centered
I just noticed my G37 coupe hood is off centered by about 1 or 2 mm to the driver side. The gap between the hood and the front quarter panel on the passenger side is about 1 or 2 mm bigger than the gap on the driver side.
Anyone know if this can be easily adjusted or do I have to bring it back to the dealer?
Thanks.
Old Oct 15, 2010 | 03:27 PM
ThatsGman's Avatar
ThatsGman
Might be the hood latches ....pop the hood and see if they are the same length maybe even unscrew them a little and put the pin back in. Happened to me when I took my TS hood off my car and put the OEM one back on. If it's like that it shouldn't be a problem.
Old Oct 15, 2010 | 04:09 PM
pcwd's Avatar
pcwd
How many screws are holding the hood latches?
Also, do you mean the hood pins? Are these pins on the hood or are they near the latches?
What do these pins do?
Thanks.
Old Oct 15, 2010 | 04:15 PM
Weiboy718's Avatar
Weiboy718
There's only 4 10mm bolts holding the hood. You can adjust it by loosening them and move it. Have a friend help you out
Old Oct 15, 2010 | 04:25 PM
ThatsGman's Avatar
ThatsGman
Thanks.
Whatever is in the front under the hood on either side ( don't know the correct term for em). I just took out the push pin loosened em up a bit dropped the hood and it fit perfectly.
Old Oct 15, 2010 | 04:35 PM
pcwd's Avatar
pcwd
Thanks. Exactly where are these four 10 mm bolts located?
Old Oct 15, 2010 | 04:40 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
they are at the base of the hood (by the windshield) on either side. 2 per side, just pull the plastic cover towards the front of the hood, then down
Old Oct 15, 2010 | 05:07 PM
pcwd's Avatar
pcwd
I think I know where these four 10mm bolts are. They must be at the base of the hood dampers. There is a black plastic cover. I guess this is the plastic cover I have to pull off.
Thanks all for the replies. I'll try these two solutions this weekend.
Old Oct 15, 2010 | 05:10 PM
hispeed-lowdrag
lol yup...that's exactly what I said
Old Oct 15, 2010 | 06:31 PM
Weiboy718's Avatar
Weiboy718
What a bunch of noob's hahaha!
Just kidding guys!
Old Oct 15, 2010 | 10:46 PM
hispeed-lowdrag
Dont lump me in the newb group Wei
Old Oct 25, 2010 | 04:28 PM
pcwd's Avatar
pcwd
I tried adjusting my hood yesterday. I loosen all four bolts. They were 12 mm. There was no room for side to side movement at all. Only up and down. The holes for the screws were just big enough for the screws.
Looks like these four screws are for holding the hood to the hood hinges. The hood hinges attach to the car body. I think these hinges might need adjustment. However, you can barely see them so I don't think you can adjust them without removing body panel.
I also tried adjusting the hood latches but that is only for the up and down fitment by the bumper.
Old Nov 1, 2010 | 09:24 PM
pcwd's Avatar
pcwd
I tried again this weekend at adjusting my hood. This time I got a friend to tighten the four 12 mm bolts while I pull the hold to the passenger side tightly. I noticed the two hood dampers tilt to the passenger side as well since it is attached to the hood hinges.
It worked this time!
I also adjusted the two hood latches at the front of the hood. The hood now sit more flush with the front bumper side to side.
Overall, the hood is nicely lined up and easier to open then before.
Thanks for all the help.
faze2988
Oct 7, 2015 12:05 AM
SpeedBallDEVIL
Oct 2, 2015 11:20 PM
Allboutcali
Sep 26, 2015 03:43 PM
