Trouble Code #P24C0
Old May 1, 2010 | 11:07 PM
Redline37's Avatar
Redline37
Trouble Code #P24C0
Hey guys. I was wondering if any of you guys could help me find out what this DCT means. I've searched high and low but couldn't find out what this code means. I found this code chart but it doesn't seem to have my trouble code on there. Infiniti OBDII Code Chart P1210-UP
Thanks.
Old May 1, 2010 | 11:35 PM
whiddles's Avatar
whiddles
you have high flow cats or test pipes?
Old May 2, 2010 | 12:08 AM
Redline37's Avatar
Redline37
Stock cats
Old May 2, 2010 | 06:52 AM
pdarby's Avatar
pdarby
Traction Control Signal Circuit
Old May 3, 2010 | 03:06 AM
ifinity's Avatar
ifinity
pdarby--what is your source for figuring out codes? I could not find a match in the 2008 service manual.
What about this source:
OBD-II Check Engine Light Trouble Codes
P0024 "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 2) - See Trouble Code P0021
C0000 - Vehicle Speed Information Circuit Malfunction
The P24 would be the most likely, with C0 some sort of suffix?
Redline37--More info from your post at http://www.*****.com/index.php?/topi...le-code-p24c0/ (why is "o u r v q" blocked by "*****"?)
says:
"I have tried contacting hypertech technical support but I still havent received a reply. I sent an email on april 23. It has been 8 days and still no reply. This is the message i sent them: HI. I have been using your hypertech tuner on my 2008 Infiniti G37 Coupe, and it has worked flawlessly! It was working flawlessly until recently when I tried to return to factory settings and then reinstall the tuner. I received the DTC p24c0. Now that same code pops up everytime I try to install or return to factory. If I were to clear the code, the code goes away and doesn't pop back up until I mess around with it again. The symtoms of when the DCT is there without clearing are: it takes longer to start up car with push button start. It seems to lag a lot longer than it should to start. An example of what I mean is: I have hypertech power tuning installed already, I connect hypertech to return to factory, i return to factory and after instructed to, i disconnect. I start up car and will recieve the DCT code. I have to connect tuner back on and erase DCT. If I were to install the power tuning after, the DCT pops up once again. I would have to install the power tuning, disconnect hypertech when instructed, start car, wait for DCT, plug hypertech back on and clear DCT, then disconnect when instructed. Only then will the DCT go away. If you can, please tell me what the DCT p24c0 is and why it started popping up recently? Thanks. "
Old May 3, 2010 | 11:19 AM
risin's Avatar
risin
If you have an iphone you can use fuzzycodes to figure out what the codes mean. Don't know what dct means.
Old May 3, 2010 | 11:26 AM
hispeed-lowdrag's Avatar
hispeed-lowdrag
^^dtc is diagnostic trouble code
vamarris
Dec 9, 2018 11:10 AM
mjnoles1
Oct 4, 2015 10:27 PM
MrRiv
Sep 29, 2015 04:59 PM
k19g37x
Sep 29, 2015 02:46 PM
Detailed Image
Lighting/Cleaning Products
Sep 28, 2015 07:02 AM
