owned by a pothole
Sevas used to crack like that all the time.
Look at the bright side, at least your airbags didn't go off..
YouTube - 2009 Infiniti G37 Airbag Defect - Bad Customer Service
^ Now that is truly getting owned by a pothole.
I also miss my car so much =(.
I hit a pothole in my G37 and my airbags went off! You are one lucky guy. Namir you are right I truly did get owned by a pothole! Check out the video I made of my car. YouTube - 2009 Infiniti G37 Airbag Defect - Bad Customer Service
WOW HOLY COW. That is insane how it made the air bag deploy. Well if you want new rims and you filed it with your insurance and have $0 detectable you should file it with your insurance. Wait that is if you want your insurance to raise a little bit.
Good luck getting that taken care of. About 10 years ago I hit a pothole by Newark Airport that took out both of my right side wheels/tires and (I found out later otherwise I would've gone to court) bent my side frame rail. It was in a 45MPH construction zone and I knew the road was bad so I was going 25-30.
Here's the pothole the next day while the guy was fixing it. There were 17 cars up the road changing tires as I was taking these pictures.
The area was horribly lit at night too so I had even less chance of trying to avoid the pothole. I first contacted the state who told me that I had to contact the construction company. The construction company told me that I had to contact their insurance company. The construction company's insurance company told me I had to contact the state's insurance company. The state's insurance company cited the Tort Act which basically says you can't sue the government with some loopholes that didn't benefit me. It wound up being about $1,100 between towing, overnighting 2 new wheels, overnighting 4 new tires (I was about ready for new tires anyway and the two on the right side were completely destroyed by the pothole), and mount/balance/align. I needed it all done quickly because I was starting a new job a few days later. That's what potholes in the tri-state will do to low-profile tires and crappy wheels. You steel steel alloys and tires with a much beefier sidewall to survive the area in the winter!
Yukkk... Thats why I don't understand why you some G37( 40k+ value) owners buy cheaper cast wheels. They might look nice but I won't put my life or my passengers at risk to save a few bucks. Might as well stay with OE wheels. At least the OEM WHEELS were well tested. First the chikara now mrr. Only cast wheels I would trust are Yokohama advans. My .02
delfinparis
Oct 8, 2015 06:06 PM
mjnoles1
Oct 4, 2015 10:27 PM
Slapshot1
Sep 27, 2015 08:40 AM
