FINALLY GOT my YELLOW TOP
Old Dec 14, 2009 | 10:40 PM
g37RN's Avatar
g37RN
My battery died when I installed the Blitz throttle control. The dumb thing wouldn't turn off
Old Dec 15, 2009 | 03:06 PM
2008G-Man's Avatar
2008G-Man
Originally Posted by B L U E S L A T E
Should have gotten Braille battery.
Braille Battery USA - B106C
Red Top will do just fine
Old Apr 19, 2010 | 05:14 AM
]\[ /-\ ]\/['s Avatar
sorry to dig this old thread up but is there some kinda kit or mounting bracket to get the yellow top to fit? its shorter and smaller compared to stock battery
Old Apr 19, 2010 | 11:25 AM
Jamler's Avatar
Jamler
That B106C the right size for the G37S?
Also I think we need Right Side Positive, to keep current wire config
Old Apr 19, 2010 | 12:32 PM
2008G-Man's Avatar
2008G-Man
I just used the original top bracket for my red top. Doesn't fit perfectly but you can get it to work well enough to hold the battery in place.
Old Apr 19, 2010 | 02:19 PM
JLai's Avatar
JLai
Use the battery cover and attach it to the bottom on the battery. It comes with the battery and is made specifically for that purpose.
Old Apr 20, 2010 | 03:12 AM
DetroitG37Joe's Avatar
DetroitG37Joe
Is this like some super battery? Do you have this installed? Does the model you have linked there work in our G's? I may invest in a top of the line battery should I ever join the DBC.
Old Apr 20, 2010 | 05:24 AM
the battery is tall enough when sitting on top of the battery cover, but the bracket is too wide for the battery...now wat? lol...this battery is frustrating for $230
Old Apr 20, 2010 | 06:49 AM
Haji's Avatar
Haji
XSPower makes great batteries that put out near 1000 amps!
Old Apr 20, 2010 | 08:05 AM
JLai's Avatar
JLai
It will fit. The front of the battery will fall into the notch of the bracket. Its not a perfect fit, but it will hold it in place fine.
And you paid $230?! Got my yellow top for $176.95 after everything was said and done.
Old Apr 20, 2010 | 08:09 AM
JLai's Avatar
JLai
My buddy's shop had 3 Brailles die on him in his race cars. Never had that problem with the Optimas.
Old Apr 20, 2010 | 09:01 AM
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
yep what JLai said... I had to remove the surrounding plastic to get the best install access.
Old Apr 20, 2010 | 01:03 PM
DetroitG37Joe
What's a yellow "top"?
Old Apr 20, 2010 | 01:18 PM
  #29
2008G-Man's Avatar
2008G-Man
Got my Red Top for less than $175 at Summitt.
"What's a yellow "top"?"
Dude, it's a battery made by Optima, a very good battery at that. Yellow Top and Red top ate two types. Yellow Top has lots of reserve capacity and can be drawn way down without issues. Red Top is less deep cycle but more amps (from memory).
Old Apr 20, 2010 | 02:10 PM
  #30
JLai's Avatar
JLai
As I understand, Red Tops have more cranking power where as Yellow Tops are deeper cycle and are better for electronics and sound systems.
I used to have a Red Top in my old car. Yellow Top fit my needs more this time around.
