Dead Battery Already
will the trick of holding the window switch down for 15 seconds, then up for 15, to reset the range work? Search for power window resetting on this site. https://www.myg37.com/forums/audio-v...n-windows.html maybe.
Or maybe need to do the ECU reset trick of blipping the accelerator pedal...search again for better details in a thread. But power windows would be the Body Control Module, I think.
Or maybe call Infiniti Customer Service and use them to tow to dealer, drain battery, and let them test and replace?
just tried it today and it worked! thanks
Do you drive short distances to work and such? My wife had a Miata, and after two years the battery died, I thought that sucked and got a new battery. About two years later we traded for and Audi, and in two year s latter that battery went dead. Come to find out because my wife drives less than a mile to work, the short trips never got the batter fully charged, so over time the battery just went out. If the G uses a lot juice for the electronics, you may not be driving long enough to recharge fully and you will eventually ruin a battery that way.
Just a thougt.
Just a thougt.
Has anyone just bought a good quality aftermarket battery instead of going to the dealer? I haven't had any problems with mine, just curious. You know, like a DieHard or one of those lightweight dry cell/Gel ones?
What do you think about the REDTOP OPTIMA. I used it with all the car i used to had and it's last long for nearly 5-6 year with alot of Mod..Specially Aftermarket stereo.
Only this G using for 3 month.WTF!! and i don't see anything better than Optima for now.
Even they have but i don't think it's reasonable price as Optima.
Also F" Manhattan Stealer try to BS to avoid paying to replace a new Battery because i used aftermkt battery.I will ask them for a prove if thier battery better than the REDTOP in statement.
had the same issue at 17,500 miles... my coupe died on me a few times then i took it in and they replaced the battery for $20 because it was just into it's second year. (said it was a bad battery) First year I think they said would have been free though.
just a question, are you guys with the battery issues leaving your lights on auto? its possible that may be an issue. i know on my solara it had day running lights and it turned on automatically as well. if i turned my car off, lights would go off as well, but sometimes the battery would die anways. its happened 3 times. now, if i manually turned of the lights i never had that problem.
i usually don't leave the g on auto, but now i just might to see if that could be the same issue i had on my solara.
