Daylight Savings Time
Old Nov 5, 2007 | 09:55 AM
gurneyeagle's Avatar
gurneyeagle
Okay, I was hoping someone else was going to ask this question, but it looks like I may be the only one having this problem.
My display clock did not reset for the end daylight savings time. I went through the manual, and it says that the system gets it's time directly from GPS. My analog clock did reset though.
I reviewed the settings and they are for my time zone and the daylight savings time box was checked.
In order to get the display to read correctly, I had to turn the feature off. That can't be right.
Any help would be appreciated.
Old Nov 5, 2007 | 11:57 AM
carman63's Avatar
carman63
Turning off the Daylight Saving feature is the only thing I can think of that works. That's also what I had to do for my atomic alarm clock.
Your analog clock automatically reset?
Old Nov 5, 2007 | 12:14 PM
JLS66's Avatar
JLS66
Weird. I had to reset the analog clock, but not the display clock.
Old Nov 5, 2007 | 12:26 PM
DetroitG37Joe's Avatar
DetroitG37Joe
yeah same thing happened to me with my digital clock it didnt reset at all i had to go to clock setting and take the dot out of daylight savings time option...it was either that or changing one time zone back to central time haha
i havent checked my analog clock yet im new to infiniti and am not even used to looking at that one to be honest...
Old Nov 5, 2007 | 01:29 PM
UNV-IT46's Avatar
UNV-IT46
i also just clicked off the daylight saving box in the options and it fixed it...
Old Nov 5, 2007 | 02:12 PM
beestea's Avatar
beestea
Mine also needed the "DST" box unchecked.
Old Nov 5, 2007 | 02:22 PM
Callaway's Avatar
Callaway
Arm flailing tube man
Same here.
Old Nov 5, 2007 | 02:49 PM
gurneyeagle
Yes, that's what made me think something was not set properly with the display clock. Maybe the system isn't picking-up the GPS signal?
To go back to another response, I never look at the analog clock either!
Old Nov 5, 2007 | 04:08 PM
mal_TX's Avatar
mal_TX
You are expected to manually go into the menu and enable/disable DST at the appropriate times of the year.
Remember, the GPS is satellite-driven, so it is the same for everyone on the planet. The GPS signal is most likely GMT. This is a common time that needs to be adjusted for your time zone. Some time zones use DST, others do not.
Rather than deal with those issues like my $80 Honeywell Thermostat can, Infiniti decided it would be best to just not deal with it at all and let us tell the system whether or not DST is in effect and applicable for our region.
So... yeah, not a great job by Infiniti, but it works fine. I'll give them a free pass on this one (lazy schmucks!)
Old Nov 5, 2007 | 04:17 PM
gurneyeagle
Thanks mal. It's no big deal; I just thought something wasn't set right. You think it would have just been easier to have a way of simply advancing/retreating the clock an hour.
For a super high tech car that is surprising. Not disappointing, just surprising.
Old Nov 6, 2007 | 12:05 PM
finagle69's Avatar
finagle69
yeah, it's a manual thing. you have to remember to turn DST on and then off.
Old Nov 6, 2007 | 12:25 PM
RedHerring's Avatar
RedHerring
With the turnback date changing because of the "do-gooders" in congress, it is probably better to leave it to the user rather than have obsolete code in the firmware of the car that changes it on the wrong day and doesn't have an override.
Old Nov 6, 2007 | 01:22 PM
mal_TX's Avatar
mal_TX
...Yep, and even better still to implement the rules as they stand when the car is designed/built and still provide the override just in case... just like my $80 thermostat.
Not a big deal but kind of lame.
Old Nov 4, 2013 | 09:40 PM
socketz67's Avatar
socketz67
Community Builder
Wanted to give this old thread a bump as the DST problem just occurred because we set the clocks back over the weekend.
Turning off DST in the settings fixes the issue, which seems backwards.
Since this thread was from 07, I was wondering if anyone knows of a more elegant workaround or if they have spoken to the dealer as it has been almost 7 years and the feature is still tweaked.
Old Nov 6, 2013 | 02:07 PM
JMS2000's Avatar
JMS2000
Whoa, hella bump! Well, we were on DST prior to the change this past weekend. We just changed back to standard time, so it makes sense to have to turn off the DST setting to correct the time. You're just disabling the hour adjustment, not disabling the feature that controls automatic adjustments. That feature still does not exist.
j50ny
Jul 21, 2017 10:46 AM
kavcheung
Jan 22, 2016 02:40 PM
inspector94
Sep 8, 2015 12:57 PM
Detailed Image
Lighting/Cleaning Products
Sep 4, 2015 08:14 AM
