Limp mode?
Old Sep 24, 2025 | 01:45 AM
blackandwhite's Avatar
blackandwhite
Limp mode?
My car will not go above 2500 rpm unless I switch it to manual mode. But there is no code as of yet.And i'm not sure if it's limp mode or not.
By brake lights are also stuck on.
Old Sep 24, 2025 | 08:07 AM
SkysG37's Avatar
SkysG37
Probably the little rubber stopper on the brake pedal arm.
they get old and fall apart. Without it the brake switch won't switch off.
I fixed mine with a zip tie nub.
Ordered a spare stock one for the glove box frome Z1.
But the zip tie is still going strong.
Old Sep 24, 2025 | 10:05 AM
LuckyJack's Avatar
LuckyJack
This behavior does look like limp mode. Check this out, seems to be the same issue as you've got..
https://www.infinitiq50.org/threads/...p-mode.145247/
Old Sep 24, 2025 | 11:01 AM
ILM-NC G37S's Avatar
ILM-NC G37S
Originally Posted by blackandwhite
By [sic] brake lights are also stuck on.
Either the brake switch failed (unlikely) or, the rubber pads rotted and broke (way.more than likely).
(photo originally posted by forum member Elco)
This issue is becoming more common as these cars are getting up there in age. Easy fix.
OEM p/n:46584-S0100 or "Dorman" p/n: 74015.
It will take longer to twist and contort your body to get up under the steering column and access the brake pedal assembly than it will to replace the pads. I would replace both and call it a day (whether you use the ASCD or not).
NOTE: if you are 6MT, there is also one pad for the clutch pedal switch. May as well replace that one as well, if applicable.
sahiwal007
39
Jan 23, 2017 03:36 PM
abravenewworld
136
Jun 7, 2014 08:13 PM
Coprolite
Motorsports / Track
Jul 31, 2012 10:29 PM
DPE_G35
Dec 25, 2009 01:01 AM
