Whirring noise when trying to open top
Old Oct 28, 2021 | 10:43 AM
Patti cakes's Avatar
Patti cakes
Having an issue when trying to open the top on my car. A month back, the top would get "stuck" when I would open it. It would stop about half way through the process but after turning the car off and on a few times, it would ultimately work. Now when I tried it, it opens the trunk but there's a whirring noise in the part where it should be unlatching and it won't. The only remedy is to turn the car off and restart it, but only to closie it. The car battery did just crap out on me and I replaced it so I'm wondering if it could be as simple as trying it again or if there is something more going on. The weather has been perfect lately so I do want to open it but I don't want it stuck again. Getting close to cold weather time so I might just leave it as is for next year but short of the "stealership", there's no one close that works on convertible tops in my area. Any suggestions on what could be the issue? I have a 2010 G37 convertible, 140K. Thanks!
Old Oct 28, 2021 | 06:34 PM
Guy Menard's Avatar
Guy Menard
did you check if your flaps deploy correctly? In many cases, a broken flap gear can result by getting the top stop and stuck while opening or closing.
on a 2010, flap will fall down and come loose when gear got worn.
Old Oct 30, 2021 | 03:54 PM
n559br's Avatar
n559br
Where are you located? This doesn't sound like a flap issue but could be the dead battery has caused a glitch in the closing sequence. Is the whirring in the left rear of the trunk? That is where the pump is located and is one of the problems I found when fixing my top.
Shoot me a pm and we can discuss offline.
Old Nov 1, 2021 | 06:54 AM
Patti cakes
The whirring noise is coming from the area above the windshield, like where the top should be unlatching. There are no noises coming from the trunk or elsewhere. It's just when I hold down the open button, the noise occurs after the trunk release but not from the trunk.
Old Nov 1, 2021 | 08:16 AM
n559br's Avatar
n559br
You'll need to use Consult to figure out what exactly is wrong with the top. If the top isn't unlatching but you are hearing noises it's possible the header lock is not functioning properly. With consult you can unlock those on their own to test.
Your profile doesn't show where you are located. There may be another member who could help.
Nickt1216
G37 Convertible
Sep 19, 2019 07:28 AM
vinsanity_2_k
G37 Convertible
Nov 23, 2015 04:49 PM
marcelo19lp
Jul 30, 2015 02:23 AM
Harveyt
G37 Convertible
Mar 10, 2014 03:16 PM
brycerocket
Sep 11, 2009 01:52 PM
