Body panels
Old Sep 8, 2021 | 12:41 PM
Erominef's Avatar
Erominef
Body panels
Can’t find anything on this just trying to figure out if normal g37 panels and hoods will fit the convertible model was looking to add side skirts front bumper and/or diffuser and a different hood but don’t want to spend 2 grand just for none of it to fit thanks for any and all help
Old Sep 9, 2021 | 01:21 PM
stugots81787's Avatar
stugots81787
front bumper is the same so any splitter made for the base or s model bumper will fit your base or s model convertible
side skirts different. But you can get away with fitting the convertible with side splitters
rear bumper is different and I dont believe any rear diffuser was ever made for our rear bumpers but I have seen some members convert rear diffusers to fit our rear bumpers. See my convertibke below with front and side splitters. Didn’t go the route of adding a diffuser.
Old Sep 9, 2021 | 01:59 PM
Erominef's Avatar
Erominef
sweet build. You got any photos with the top up. Also do you know anything about hoods really like the look of these vented hoods I’ve been seeing on coupes but don’t know if they will fit the convertible
also bolt on wide body kits should fit the convertible too right as there’s not much fitting there
Old Sep 9, 2021 | 02:20 PM
stugots81787
hoods are the same but id stay stock unless you’re going full carbon fiber. These duraflex hoods are made like crap and you’re going to spend a whole lot more to get them fixed to fit the correct way.
again I’d be careful on the wide body kits because of the slight difference on the sides from the convertible compared to coupe. If you do go that route plan on spending a ton of money to get them on correctly. I highly doubt you’ll find a direct bolt on without having to do any modifications after that.
that’s top up with my old rims. Don’t have many pics of the car with the top up
if you have the money to spare I’d throw a turbo charger in it !
Old Sep 9, 2021 | 02:51 PM
Erominef's Avatar
Erominef
planning on throwing a turbo in there as for the hood I just liked the look of the vented ones kinda sucks about the wide body but that would a good bit in the future so will have time to figure that out thanks for the help
Old Sep 11, 2021 | 08:24 PM
kiseliok's Avatar
kiseliok
G37 Community Team
You can run 11" wide wheels in the back - why do you need to go out more?!
It'll probably be cheaper to build a customer fiberglass kit from scratch than try to fit an existing one. Vert booty is completely different from the coupe.
Like stugots said - if you are going to replace the hood, don't skimp out and get a good qualify cf one. Unless you don't mind weird gaps and rattles, of course.
G3727
Jul 22, 2021 09:29 PM
Rogue_G
Feb 20, 2020 08:00 PM
Kingston Kustoms
17
May 15, 2015 12:56 AM
AUTOKITS-X
Interior/Exterior Items
27
Aug 17, 2013 11:33 AM
solarg37
12
Apr 21, 2013 11:49 PM
