I'm looking for a subwoofer to fit into my spare slot in the trunk as the bass in the car is a lot worse than my previous G37. I want to keep the car as OEM as possible, but I haven't had any luck in finding one to fit my spare tire. I bought a Nissan FX subwoofer as supposedly it would fit into the spare tire that the G37 provides, but it was too big.
Why not just build a custom enclosure with a shallow mount sub like this: https://www.jlaudio.com/collections/...bwoofers-92184
Any reputable audio shop will make a custom mold to the spec of this sub and you might even have some space left, depending on whether you want it ported or not.
Something tells me there isn't much of a market for convertible spare tire subs so this might be your best bet.
Does anyone know where I could find one?
How about one from a 370Z? That will likely be the closest you can get to the G...
As Kiseliok mentioned, you might be better off building your own for a more custom fit.
I agree with the custom setup however if you'd like to keep it factory then the 350/370z Bose woofer should be able to be swapped for the oem which I doubt it will be any different.
Unsure if the factory system will support both connected.
I am of different mindset. I say keep the spare. Better to have and not need than to need and not have. That being said, I hade custom box made for mine. And retained ALL my trunk space. Incidentally, its for sale too lol
I just traded in my G in yesterday. I have the enclosure, sub and amp for you.
Custom Enclosure for G37 Spare tire slot
Alpine PDX-V9 Amp (remote sub **** not included)
Alpine SWR-T12 12-Inch 1800 Watt 4 Ohm Shallow Mount Subwoofer
$500 plus shipping
(update) just remembered that’s the spare wheel slot
did the convertible part still go down? Doesn’t look like you have the separator correct me if I’m wrong thanks
Reason: Update
I did the same thing. The height for the entire box has to be under 5.75". Mine sounds amazing. Top works fine. Lots of Dynomat under the cover to prevent a flapping sound. For best results, tap into the 6x9's speaker wires because your bass **** will work just like a sub control as only low frequencies will be going out from those.
This works very well:
NVX XFLOC2 2-Channel 80W Line Output Converter with Digital Noise Filter + Line Driver
Zero unwanted noises.
Sub barely fits:
Pioneer TS-A3000LS4
Shallow-mount 12" 4-ohm subwoofer
Amp isn't mounted in the pic yet. It's a Kenwood and doesn't get hot at all. I also upgraded the tweets in the sail and that made all the difference. The system is perfect with a good sub and better tweets.
Reason: link.
